[OFFICIAL THREAD] NMC 0.7 alpha.1 bugs
  • [OFFICIAL THREAD] NMC 0.7 alpha.1 bugs
    Here ya go.
    Let me know the bugs you've found
    FIXED = green text
    THIS IS NOT IN ALPHA.1:
    - no equalizer
    - multiselect in "add to playlist" is buggy
    - no images resize optimization in the playing modules (only external apps and filelist)
    - no minimize in external apps
    - no "keypad" mode in the OSK (missing skin files to made)
    NMC BUGS:
    • error 13 directly after installing when starting NMC, must load NM to go.
    • error 13 when clicking on filelist from images with embedded audio
    • changing show mode in images module restart image fading
    • Start it up, choose music from menu, then click home. I get a runtime 5 invalid procedure call. no music is playing at this time as I dont have anything installed on the laptop. Maybe because the $string is empty its causing te error
    • keypad mode skin is missing (no code is missing, just the skin..)
    • I create an application: path is "c:\windows\explorer.exe c:\" and finding text is "Local Disk". I launch it from NM. Not only it does not show but when I click on Exit on your "taskbar", the PC reboots. If I run it not embedded, I still don't see it, but at least it does not reboot
    • bug in the selected background image: not resizing good and showing crappy image (grey pattern)
    • "add file" in playlist mode is sometime giving "error 5"
    • clicking "home" on the filelist sometime crash with "error 340"
    • bugs in showing variable bitrates
    • no "C" key in the normal keyboard mode
    • playing VBR file and changing module crash NMC
    • Added Notepad as an external application. When I use the OSK clicking with the mouse, everything is ok. If I use the touchscreen in that same session, I can type words too. If I quit this session and start another session with notepad, but start typing the OSK with the touchscreen, Notepad looses focus (the words File, help etc of Notepad become grey) and nothing gets typed in Notepad. If I regain focus by tipping my finger in the Notepad area and retry typing the OSK with the touchscreen, focus gets lost again. If I regain focus and type the OSD with the mouse, everything works like it should again. Afterwards typing with the touchscreen works again. Hope you can follow this difficult explanation.
    • date is hiding when switching from VIDEO to MUSIC
    • scrollbar is not reseting when changing folder in the filelist
    • audio > GPS -> OK ; close GPS > audio -> OK ; audio -> GPS -> NMC is hiding and no GPS app showing but remains in the taskbar. Must close with taskmanager.
    • Using "description" in the audio module never shows mp3 information defined by <format></format>
    • first time i go to audio module, then i start the filelist to play something, NMC crashes. Must go from main to filelist then play a file
    NM BUGS:
    • "deactivated" not fit in "Force close button"
    • in "Application list", the fields <path>, <finding text> and <description> all contain "Text1", until an existing application is selected.
    • I have not found how to run an application with parameters, like "C:\program files\gammacontrol.exe /day", even with double-quotes.
    • add a menu to launch directly NMC from NM
    NSW BUGS:
    • Anytime you save in NSW it sets active/inactive settings to "True" or "False" instead of "Vrai"
    • In EN translation the text entries mp3_* all show up as mp3_year vs mp3_debit, mp3_frequence and so on. However when you click on any of them the "Control description" Shows what it SHOULD be.
    • no default format when adding a text control
    • When clicking on a control in the left pane (can be button/text etc...), you cannot delete it by pressing the del key, only if you click the control on the right (design-) pane.
    • When changing properties of controls (font, fontcolor), you need to click in another textfield on the left pane to 'save' the changes. When just clicking on another control, the changes are lost.
    • The Height, Width, X and Y Coordinate entry behaviour is... annoying. The previous version was much better. It won't let you have an empty box.
    Installer BUGS:
    • - vb6fr.dll, msinet.ocx, mscomctl.ocx, gdiplus.dll missing
    • - When selecting an offline networkdrive in the setup (dest dir), error 68: "Périphérique non disponible" or something.
    • - noticed that the default install dir is into a temp dir rather than program files/nmc
    • - selecting "mode touchscreen off" is not saving config correctly
    • - cannot select a hard disk root for favourite folder (\\ in the path)
    NS - neocar suite
    http://www.neocarmediacenter.com
    awesome m8, noticed that the default install dir is into a temp dir rather than program files/nmc I will update this post if I find anymore..
    Got a runtime 13 error on the first run, but seems to be fine now
    NM -- General options -- Force close button
    The deactivate text doesnt quite fit
    NCM --
    Follow me on Twitter
    http://www.FreeICE.co.uk
      Installed correctly ? Working ?
      NS - neocar suite
        Give me plenty of bugZZz
        NS - neocar suite
          will play more tomorrow, I must say I'm very impressed with all your work so far, its awesome. Some very nice ideas and your skin rocks. I'm sure theres loads of things I havent seen yet.. your osk rocks.. even if its not UK yet ;-) Dont let these little bugs get you down.. Cant wait to do some more testing in the morning
          Steve
          CdrSkull
            The visual basic phantom is back.
            I have got a fresh install of W2K SP4 with all MS updates on my M10K Epia board. Only other things installed : drivers mobo and touchscreen Lilliput. The installation of NMC07 alpha1 stops nearly instantly with following fault :
            Car : Hyundai Tucson
            Carpc :
            Lilliput 7" touchscreen indash 90% done
            PSU : M2-ATX
            Epia M10K /512DDR/80GB Maxtor
            Software : Windows XP Pro 100% done
            RR with DigitalFX skin
            In car : 80% done
              Look for the solution for that error in the 6.5 version... I think it existed already but had a fix...
              List of front-ends/usefull apps
              XTroniC | XTroniC Direct
                I know, but just reporting ...
                Copy the file to your system32 map is the sollution.
                Carpc :
                PSU : M2-ATX
                In car : 80% done
                  When selecting an offline networkdrive in the setup (dest dir), error 68: "Périphérique non disponible" or something... Not very serious error anyway...
                    when installed freshly, the gps button gives "indice en dehors de la page"
                    I guess it is not configured. I'll check.
                    When installing over an existing install, it doesn't work (just starts with a white square box instead of the program). Delete the nmc folder and setup = works.
                      i get tons of errors when trying to watch my music videos, like run time 9, script out of range.
                      How in the world would you put the special AirPort card in a PC? Mine is a Mac anyway but it's too old to AirPort. I just use a zip drive to transfer.
                        After placing vb6fr.dll in system32 map, install went ok. If I want to start Neocar Manager, I get following error , even after rebooting the machine. Will search for MsComCtl.ocx on another machine where v065 is installed, add it to my system32 map and try again.
                        EDIT :
                        After adding and trying again, I got a message about gdiplus.dll missing. Added again to my system32 folder and now NM opens.
                        /EDIT
                        Carpc :
                        PSU : M2-ATX
                        In car : 80% done
                          When using version 07 with an older skin, it just shows the white square instead of the program...
                            Is the .net framework installed? Don't know if it's needed, but the mscom blabla .dll sounds familiar...
                              Installer error
                              Hi,
                              My first Try for Neocar...
                              When I run the installer I get this error:
                              The Language DLL 'vb6fr.dll' could not be found.
                              FYI I am using a English Windows XP version.
                              Cheers and keep up the GOOD work....
                              Update: Found the missing .dll works again ..
