[OFFICIAL THREAD] NMC 0.7 alpha 1c bugs
  • [OFFICIAL THREAD] NMC 0.7 alpha 1c bugs
    ALPHA 1c BUGS:
    NMC:
    • When playing a WAV, NMC shows the last played MP3's infos
    • When playing a audio file, i get sometime i error 5 while selecting a NPL playlist in the filelist module
    • WMA icons not showing in the filelist module
    • When playing a NPL playlist with folders, when the file is passing to the next, a bad file is played (not the next)
    NM:
    NSW:
    • BIG ERROR: NMC is not reloading the base skin resolution so when saving NMC crashes
    IMPORTANT: READ THIS CAREFULLY -> http://www.mp3car.com/vbulletin/show...398#post314398
    NS - neocar suite
    http://www.neocarmediacenter.com
    i ran the installer then it extracts all the files then that's it...
    no rosponse. nothing happens then. is this only me? why?
    i have p4-2.8 512mb xp sp2
      Netsuo, if you set a base resolution in a skin with NSW, it always resets to its original settings. It seems the new resolution is not saved. Can you check this? I want to see your light skin at 1024x768. Probably I can set it by hand also in the xml of the skin, but just want to know if it works on other pc's.
      <edit>
      I checked. In the xml file of the skin, the resolution is set as it is saved. Only if you open the informations in NSW, it seems there is always standing 800x600, and not the resolution that is in the xml file of the skin. Solved my second problem too. I had to set the resolution it displays on my screen in the skin section of NM. (stupid me)
      </edit>
      Car : Hyundai Tucson
      Carpc :
      Lilliput 7" touchscreen indash 90% done
      PSU : M2-ATX
      Epia M10K /512DDR/80GB Maxtor
      Software : Windows XP Pro 100% done
      RR with DigitalFX skin
      In car : 80% done
        You can set the skin resolution in NM, in the skins options
        In NSW it's only the physical skin size (to be entered originally by the skin's designer).
        NS - neocar suite
          I noticed sometimes the date disappears in the audio module ( after switching to other modules and back). Have to figure out when it exactly happens. I'll let you know.
          Carpc :
          PSU : M2-ATX
          In car : 80% done
            If you pause a film, go to music and then return to video, the film resumes, but without sound. If you push the play button, you get sound again. I noticed that the wave slider is at the bottom at that moment (I told NM to manage the wave volume)
            Carpc :
            PSU : M2-ATX
            In car : 80% done
              If I go to the module photos and click the photo, it goes full sreen with audio bar. Clicking again is real full screen and if I ckick again to go to mormal mode, I get an error : erreur d'execution '340' L'element du groupe de contrôles '247' n'existe pas.
              Carpc :
              PSU : M2-ATX
              In car : 80% done
                1b: Light Works
                1c: Light Works
                1b: Onyx works
                1c: Onyx broken
                Run-time error '9':
                Subscript out of range
                Any ideas what might have changed?
                2001 Pontiac Grand Prix GTP Sedan (Sold)
                2007 Scion tC
                WhereIsMyGPS.net Online Tracker
                http://www.cardomain.com/id/leddy
                  read the post about skin physical resolution. Open NSW and go to the skin infos
                  NS - neocar suite
                    Seems like shuffle and repeat buttons are switched in the music module when pressed. And on the main module, the shuffle and repeat buttons don't seem to work at all?
                    As for the rest: this software kicks ***! YEAH! (like a happy man )
                    List of front-ends/usefull apps
                    XTroniC | XTroniC Direct
                      Fixed.
                      Didn't click save twice
                      2007 Scion tC
                        In the file list:
                        <description>
                        <format>Artist: %artiste%/Album: %album%/Song: %titre%/Year: %annee%/Length: %duree%/Genre: %genre%/Frequency: %frequence%/Mode: %canaux%/Bit Rate: %debit%/</format>
                        </format>
                        It still shows the default you programmed in
                        Not my formatted one
                        2007 Scion tC
                          i know, this why i have changed the system.
                          NS - neocar suite
                            I am getting the runtime error 5 a lot, just thought I add my thought at this time. Sorry I am still kind of dimm.
                            You can still have something if you have nothing
                              Ok for the bug but i have questions about this error:
                              - Where ?
                              - When ?
                              - What version you have ?
                              NS - neocar suite
