Skinning issue.
  • Skinning issue.
    Every time I select the images for my Main menu module, I dont ever see
    anything.
    Is there something Im missing, or am I bugged?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Please more explain i cant figure what you say
    NS - neocar suite
    http://www.neocarmediacenter.com
      I open skin workshop.
      Create a new one.
      Under the properties I set the images for the main module.
      I never see the images. If I open the skins folder itself, They are there, but not when I edit.
      If I open your skin, and change the files with my own pictures, then it works.
        have you copied your skin images to the skin folder ? (NMC_folder/skins/your_skin)
        named MENU_EMPTY.png (or JPG, GIF, BMP) MENU_OFF...
        NS - neocar suite
          Which image format is preferred? png and jpg are smallest in size? But are they the sharpest?
          Car : Hyundai Tucson
          Carpc :
          Lilliput 7" touchscreen indash 90% done
          PSU : M2-ATX
          Epia M10K /512DDR/80GB Maxtor
          Software : Windows XP Pro 100% done
          RR with DigitalFX skin
          In car : 80% done
            i think the better quality / size / NMC useability is PNG
            NS - neocar suite
              They are in the skin folder, I guess when I selected them, it copied them over?
              but they are there.
                I think you need to move them manually to NMC/skins/custommx3/ (assuming that is the name of your skin... I saw it in the screen shot you posted)...
                Roy
                2005 Range Rover 4.4
                  I did, same issue. (even though they were already there)
                    try to use other filenames or set these in lower case.
                    (i say something why dont really see what's happening )
                    NS - neocar suite
                      Alternatively, compare the xml being generated with the one from the skin.... maybe the paths are getting mixed up somehow...
                      Roy
