Destinator 3 Embedded request
  • Destinator 3 Embedded request
    Lo fella.. I know you have alot on your plate.. but would it be possible to create a external app, that you can configure the embedded window, like you can the embedded filelist, so you can put buttons round it ?
    This is my idea anyway below.. At the moment D3 sits above the skin, rather than in it.
    Follow me on Twitter
    http://www.FreeICE.co.uk
    to give you a better idea of what I mean, here a pic of what I need the window for.. everything inside the red square is D3 (skinned of course)
      i know what you want to make. Before actual system NMC was created to work as you want.. but i've changed for some code reasons.. Must see if i can find a way to make this available
      NS - neocar suite
      http://www.neocarmediacenter.com
        Sure it can be done pretty easily, just use windows api to make the Des a child of the app that you want, and then use the sendmessage api to configue the widh hight and frame style...
          Man, i allready have a "apps embedding" function working with API's, but what i say is just "i must see HOW i can include this function in NMC to make it simple to use and to configure"
          NS - neocar suite
            Wouldn't this affect the update speed of D3 though? I've noticed that 1.1.3 has some kind of latency problem as my position on the map is roughly 2secs / 30yds behind actual position where 1.1.2 was spot on. 1.1.3 also seems to take longer to load and will not embed in MediaCar on my setup no matter what I do.
            *** Having said that though, I'm now using NMEA on 1.1.3, and 1.1.2 uses Sirf...
            John
            My Nissan 200SX @ Silverstone
            NOW SADLY WRITTEN OFF!
            My Car's spec list + pics
            Stealth CarPC fab'ing...
              On my system Desti3 is not affected by the embed... it work perfectly
              NS - neocar suite
                Why are you using the D3 front end rather than embedding the D3 object in your application directly?
                If I understand the D3 frontend is a stand alone application, if you wanted to you could just integrate the actual D3 core functions directly into your own application?
                  I use D3 frontend rather than embedding it why i dont have any time to make this yet. This will come with release 0.8 of NMC.
                  I wish to finish some functions before starting to embed any GPS software.
                  NS - neocar suite
                    Right, but if you had all the time in the world you would embed it into the application directly right? I'm doing the same thing the applicaiton that I use and I just want to make sure I'm heading down the right road.
                      I think that the best solution is to embed destinator directly using SDK. This is why i will make like this
                      With this solution you avoid any "window embedding" problems (and there's a lot of them) like any external apps module the frontends propose now
                      NS - neocar suite
                        I'm writing my own prog, and I embedded the D3 (not the FrontEnd) into the prog, I also Forced it to have no Border so the user wont be able to change the size and possition of the D3...
                        I think it is better to emmb the D3 into your app. (if you have time for it).
                          YEAH! D3 sdk "embedded" in nmc and I will donate 150 (and I'll buy a license of D3, of course!). Just trying to buy you
                          List of front-ends/usefull apps
                          XTroniC | XTroniC Direct
