Big Nmc's Bugs Inventory !!!
This is a sticky topic.
  • Big Nmc's Bugs Inventory !!!
    Hello @ all
    To wait before the soon upcoming new NMC website, i've made a little temporary page to let you add any bug / problem you find in current versions of NMC.
    So, you juste have to go here:
    http://www.neocarmediacenter.com/V2/?language=EN
    And fill out the little form to add the bug you've found to the new site's database.
    With this little-time-taking thing, you'll help me A LOT by making a big bugs inventory. I will then read all of them and answer to questions, add informations on debuging, explain things etc. for all bugs.
    So, please help me by filling out this form EVERYTIME you find a bug or have a problem with NMC.
    Thanks a lot for you support and interest about my project and keep ready for next NMC stories
    NS - neocar suite
    If my hardware is ready again, i'll be doing some heavy testin'
    List of front-ends/usefull apps
    XTroniC | XTroniC Direct
      Netsuo any chance we can see bugs already submitted so we can not resubmit, or add info to existing bugs, or suggest workarunnds?
      Roy
      2005 Range Rover 4.4
        No. SOrry. Just add when you think of a thing.
        I will not release the site until it's not finished. It's 50% done now
        NS - neocar suite
          New NMC - Can't get it to work, get the VB fail. and have tried installing it separet to, but it doesn't work..
          Anyone who can help??
            What's exactly your error ?
            NS - neocar suite
              Runtime Error 0
              Failed to load 'vbalExplorerBarCtl' from vbalexpbar6.ocx. Your version of vbalexpbar6.ocx may be outdated. Make sure you are using the version of the control that was provided with your application.
                Originally posted by Dark_Stranger
                Runtime Error 0
                im getting the same thing, on my home PC
                [M10K][TinyXP][Roadrunner Frontend][OEM Enclosure]
                [iGmon]
                Download MP3 MixTapes
                  Please check this thread:
                  http://www.mp3car.com/vbulletin/showthread.php?t=47987
                  NS - neocar suite
                    I've got a problem it seems when i watched some images then went back to main menu and clicked the audio button the loading screen just hangs there.
                    I have to push the NMC in the taskbar for it to get past the loading screen
                    that is very annoying in the carpc enviroment where the taskbar isn't available.
                    It happens when i start and go tot he main menu then to the audio part just hands till i click the NMC bar in the taskbar
                    CarPC Status:
                    GPS: 99%
                    Hardware: 99%
                    Software: 92%
                    Case Install: 99.9%
                    Dash Install: 100%
                    Car Install: 72%
                      Ok, please add this bug to my site's database using menu
                      If your read the changes.txt file, there's a tip to this problem:
                      "- ADDED: click on any corner of loading screen to hide it"
                      NS - neocar suite
                        It was 1am when i finally got to try it and i was stuffed so i didn't test it out as much s i would of liked i'll check it out more later
                        CarPC Status:
                        GPS: 99%
                        Hardware: 99%
                        Software: 92%
                        Case Install: 99.9%
                        Dash Install: 100%
                        Car Install: 72%
                          Hello, I have downloaded the latest version and discovered that you have some problems with keyboard. When I pressed shift or chaps lock it doesn't work. if you press 9 the programm exit because of error.
