New version is OUT !
  • New version is OUT !
    Here it is, the new NMC version.
    Please read readme and changes.txt carrefully, thanks.
    If you have any problems let me know, i'll update as fast as possible.
    Here are the infos and download:
    http://neocarmediacenter.com/?page=d...=3&language=EN
    NS - neocar suite
    http://www.neocarmediacenter.com
    YEah!
    When I get my HDD replaced I will install it and test!
    Right now i'm talking to myself "dans les bouchons vers bruxelles"
    List of front-ends/usefull apps
    XTroniC | XTroniC Direct
      For user that have allready downloaded this version, please disable "always on top" option in neocar manager.
      I've detected that this cause problems with external apps, so i update download file now with "in-code" disable for this function.
      Thanks.
      NS - neocar suite
        Excellent, downloading now - :-)
        : Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
        : Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
        : BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
          I'll try it out tomorrow ...
          Car : Hyundai Tucson
          Carpc :
          Lilliput 7" touchscreen indash 90% done
          PSU : M2-ATX
          Epia M10K /512DDR/80GB Maxtor
          Software : Windows XP Pro 100% done
          RR with DigitalFX skin
          In car : 80% done
            Damnit im just about to go to work now i'll have to wait till i get hom which is 9 hours away
            Thanks for releasing it tho
            CarPC Status:
            GPS: 99%
            Hardware: 99%
            Software: 92%
            Case Install: 99.9%
            Dash Install: 100%
            Car Install: 72%
              dling now!!!
              Roy
              2005 Range Rover 4.4
                OK,
                I think I have isolated application problem... try setting your resolution in NM as 800x480.... then it doesnt work at all... it is resizing the application wrong!
                I am able tog et it to work if I put "use skin resolution"....
                If you cannot reproduce the problem I will post screen shots...
                I also had NMC crash when toggling open application going to MapMonkey... dont know exactly what happened but nmc gave an error and exited...MapMonkey and notepad remained open (2 apps I was swtiching...)
                Roy
                  I dont have made any tests using other resolution than 800x600.
                  NS - neocar suite
                    (will be correcting some bugs as this one from external apps and release an update this night)
                    NS - neocar suite
                      I have installed the runtimes but it will not start.
                      Starting NM I get "runtime error '0'" and when click 'ok' I get "failed to load control 'vbalexplorerbarctl' from vbalexpbar6.ocx, your version of vbalexpbar6.ocx may be outdated. Make sure you are using the version of the control that was provided with your application
                        I know this error. This is a conflict between DLL versions.
                        Please search for "SSubTmr6.dll" in all your folders, delete ALL versions of this file, just let the one in "system32" folder.
                        Now go to Start menu > run > regsvr32 c:\windows\system32\SSubTmr6.dll
                        If the error continue, just make the same thing for the file called "vbalexpbar6.ocx".
                        This will normally get rid of the problem.
                        EDIT: here's a thread -> http://www.mp3car.com/vbulletin/showthread.php?t=47987
                        NS - neocar suite
