HELP!! Vbalexpbar6.ocx error
  • HELP!! Vbalexpbar6.ocx error
    Last night i thought i would clean up my PC so i uninstalled a few old programs that iv not used for a while. Now i cant run NMC ( or NM or NPC for that matter). I have tried removing and reinstalling, and also downloading VB runtime files but still no success
    HELP PLEASE!!
    Also deleted the file vbalexpbar6.ocx, then reinstalled NMC which reinstalls the file but still get the same
    First i get error 1, then i click ok and get error 2
    Epia MII12000, 256MB RAM, 40GB laptop HD, slim DVD/CDRW, M1-ATX, 8 in 1 card reader/writer, Pioneer indash screen (waiting for K301 touchscreen)
    Do a search on your PC for more than one version of vbalexpbar6.ocx, also run a regsvr32 on it to ensure it is properly registered.
      i searched and i only have one version of the file.
      also ran regsvr32 but still no luck.
      can u just confirm that all i do is:
      start
      run
      regsvr32 vbalexpbar6.ocx
      i done this and got the regsvr32 succeeded dialog.
      Thanks for the suggestion.
        yup thats correct, do you also have ssubtmr6.dll I think its called, its a dependance of the vbalexplorer bar.
          OK its working now. I restarted the PC and also ran regsvr32 on ssubtmr6.dll and its working now. Cheers for the help UK MP3Car.
            I have a problem with install of this file ssubtmr6.dll.. sorry i wasn't here to respond, i was knowing the answer...
            NS - neocar suite
            http://www.neocarmediacenter.com
              No prob netsuo. Cant expect you to be here 24/7 to respond in an instant (even though its great when u do!)
              At least i got it working now
                Hello, I have the same problem that the user spaceman but I am Spanish and I do not understand well like fixing my nmc so that it works, serian so amiable to explain with faciles words in ingles to be able to use I a translator and power to make work my mmc, many thanks
                  This is what i did:
                  click start
                  select run
                  Type "regsvr32 ssubtmr6.dll"
                  click OK
                  Then you should see same as picture. Click OK.
                  Hopefully, now it is workin.
                    Originally posted by spaceman
                    This is what i did:
                    click start
                    select run
                    click OK
                    Spaceman.....THANKSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS!! !!
                    Thanks all
                      No Probs
