Problem installing NMC
  • Problem installing NMC
    Hi
    i get the following error while trying to install nmc
    any help ?
    thanks,
    Paul
    i had this problem before i think i had to download the vb6 runtime files.
    I think it was the same problem not sure but no harm in installing the runtime files
    Also you might not have set the language in NeoCar Manager select English and then save see if that helps.
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
      well īje ne parle pas francaisī so i switched to english from the install console and back and forth to french but no luck so i guess it must be the vb files.. will install the vb runtime files and try again...
