How to Copy a DVD in NeoCar Script
  • How to Copy a DVD in NeoCar Script
    Hey Guys
    Just thought id try to liven up this prt of the forums
    So i thought we could post some NeoCar Script stuff
    So i thought id post some command lines for copying a DVD
    Im using DVD Decrypter for this:
    dvddecrypter /mode isoread /DEST "C:\[DISC_LABEL].ISO" /start /close
    the MODE is to create an ISO image onto the harddrive
    the DEST is were the file will be saved and [DISC_LABEL] is used so it will put the lable of the dvd e.g. astroboy.iso
    START is to start the program stright away and CLOSE it to close it once finished copying
    Now If you create a shortcut to dvd decrypter and use the above for the commandline then u can set it to minamize when started so it will popup for 1second then go away and then will close itself when done
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    pretty cool, how long does the process take? I have a panasonic slot load, I think its something like 4x dvd speedor something... the standard model that everyone has you know?
    and how do you plase the ISO? Is it possible to change the iso into a roughly 1gb AVI? If I remember dvddecrypter didnt do that, right? just copies the raw data right?
    Roy
    2005 Range Rover 4.4
      I'll set my dvd burner to 4x speed when making the iso and tell u how long it takes.
      It only copies it to an ISO file for burning or mounting onto your system if u can mount it.
      It can't create it stright into a 1gb AVI file it just copys the raw data so i can burn the raw data on a disc.
      CarPC Status:
      GPS: 99%
      Hardware: 99%
      Software: 92%
      Case Install: 99.9%
      Dash Install: 100%
      Car Install: 72%
