Need Testers for Mappoint embedded Navigation System
  • Need Testers for Mappoint embedded Navigation System
    Hi,
    I have just finished testing Alpha version of Voice guided Navigation system. I need some testers for testing the alpha version. I don't want to release till some of you have tested it and given a green signal. As you must be aware that Mappoint does not support turn-by-turn direction by default I have found a work around and seems that it works most of the time, expect when the turns are very closeby its not very accurate. Also its not easy to find wheter you made the turn or not. Here is the list of main feature it supports as of now.
    1) auto zoom in at higher speeds.
    2) Voice guidance for the next turn when you are near the turn , the distance depends on your speed. Also if you are using winAmp it will pause it for the guidance and resume again later
    3) Configurable Autorouting feature
    4) Voice commands support:
    "Computer" to get into the listening mode
    and the commands are
    a) Zoom in
    b) zoom out
    c) Guidance off
    d) guidance on
    e) When is the next turn
    f) Reroute
    eg "Computer Guidance off" will switch off the voice guidance
    5) Supports skin
    Presently compiled and tested in W2K
    For testing you will require the following
    OS: win2k/xp with speech engine installed (haven't tested on win98 so not sure)
    Harware : GPS mouse and of couse the carPC
    software: Mappoint 2002
    Also you will need either a keyboard or OSK to enter the route.
    You can now download it from http://212.19.79.238/~satish/
    ThanX to Skippy76
    Warning: Its a alpha version so expect a lot of bugs
    Regards
    Satish
    VOICES Status : Rework in Progress [||--------](20%)
    Preview Version at http://voices.techworldonline.com
    Cool I sent you a PM. Will this be able to work with MediaCar?
      Yes as an external application it should work . The application will be hosted on Skippy's site soon .
        The new version is available at http://212.19.79.238/~satish/
        thanX to Skippy76 to make a web space available to host the files.
        New commands
        a) computer Take Me home (In the ini File enter the complete home address. )
        b) computer what is my current speed.
        also distance remaining from main destination bug has been solved .
        regards
        Satish
          wow this works like a charm. This is the best thing to happen to mp3car since media car. PM coyote and get this intergrated into mediacar as the defualt mapping software.
            worked fine with mappoint 2004 and XP but only tested quickly, say 5 mins
              I would really like to see this integrate within MediaCar as well. What do you think about that SilentAdmirerer?
                Plan is to help any one to integrate it any software . So that the end user gets what he wants for free
                  Im up for it...
                  2011 Nissan Frontier SL
                  AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
                  OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
                    a new version should be available to download from skippy76's site by tomorrow evening with more features like current speed,direction heading ,ETA and some bugs removed.
                      This works great, however is the virtual keyboard there supposed to work with the application? The keboard thing works on my laptop but when I copied it to the car comp it just stayed minimized in the start bar, nothing happened when I clicked it. Anyway, awesome job man!
                        ThanX
                        the virtual keyboard is like an osk and will work with any appilcation . Please check the kB.ini and change KeyBD=0,0 then the keyboard should be on the left top when u click the icon.
                          Awesome. How is the onscreen visual alerts comming. I don't have any Software porgramming skils but tons of graphic skills. Let me know if I can Help.
                          I PM Coyote (mediacar) asking him to contact you to get this integrated with MediaCar. Thanks for the tip about the INI file and automatic Re Routing
                          Cheers
                            ThanX
                            I ran out to the car just now, tried that, but still didn't see it. After I raised the resolution and brought it back down to 800x600 it showed up. When I tried to use it, it just beeped at me and wouldn't input anything. It's kind of strange it works fine on my laptop.
                            another thing, what is the syntax used to enter your home address in the .ini file? comma seperated? I'm assuming thats the little button with the road and the box?
                              I think the Home address is used to launch another application liek medicar or media engine.
