News / Releases
  • News / Releases
    New regarding release etc. will be posted here.
    The latest versions of this software can be found at:
    http://212.19.79.238/~satish/
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
    Beta 1.0 is now available
    Satish has now made Beta 1.0 available from the website.
    06 Volvo XC90
      Beta 2.0 now available
      Beta 2.0 can be downloaded from
      http://212.19.79.238/~satish/0.2.0.0/
      VOICES Status : Rework in Progress [||--------](20%)
      Preview Version at http://voices.techworldonline.com
        This is a quick update of what I am presently working on
        1) MP3 - Done
        2) PlayList - Done
        3) Radio - Done
        4) Mixer - Done
        4 GPS (Almost done)
        For this version PlayList and Mixer does not have voice support
        The UI for GPS has changed a little . The GPS Control Image is replaced with GPSMainMenu and each button except for Brightness will load the dialog .
        @anitmatter how do you think the Route options dialog should look like
        the Options in this dialog are
        1) ETA
        2) Distance Remaining
        3) Reroute
        4) shortest/quickest/preffered route.
        @ozoffi. Presently working on route import.
        Regards
        Satish
          Yes, Yes and again YES GREAT!
          Regards
          Oliver
          http://picasso.zoffi.net
            okay
            1) ETA
            3) Reroute
            Is the ETA just a button that if you push will show you how long you have until you get to the destination (basically you push the button and it pops up a number)?
            Is Distance remaining the same sort of button?
            I think that for number 4 it should have all three buttons lined up next to eachother and you can only select one at a time. When you push 1 button the other two pop up.
            Can't wait for the next version
            I do have a couple of questions on how you are handleing playlists (database or non database?)
            Cheers and good work
              Satish, what radio are you supporting?
              Craig
              Audi S8 supercar
              Modded Xbox 400GB HD
              Rear 7" screen & navplus
              Toyota Hiace Van
              Shuttle PIII 866 256Mb 10GB OPUS powered
              MediaCar & Mappoint 2004
              Custom fit 7" TFT VGA TSK
                I think we really need to make it database dependant. Databases are useful for many things one being speed. HOWEVER, I do not think we should run it off an access database as media engine does. It is slow and cumbersome. I say a ms sql engine?
                What do you guys think?
                Asus Pundit Barebones PC
                7" Lilliput LCD
                P4 2.8ghz 512mb 120gb
                Windows XP Pro, VOICES
                Sony Xplode 10in Sub, Rockford 600w amp
                Pioneer 6x9's and 4x6's, Kenwood 4ch amp
                Black Widow Alarm with Pager
                  I think database is absolutly necessary. So you can do sorting by genre, title, artist and so on. Also some smart playlists like being able to rate songs would be nice.
                  Access sucks majorly. Sql is probably overkill. What do you think Satish?
                    I don't think sql is overkill...its efficient and powerful exactly what we want voices to be!
                    7" Lilliput LCD
                      I am not a DB expert.
                      I want fast and realiabilty
                      So if that means SQL thats what it means.
                      What will that mean for the end user. What do I have to install on my end. Will there be problems distributing it in Satish's software?
                        Nope, you can include an engine with the software...that means it installs with voices.
                        It WILL make the install files larger, but that said...it WILL be faster (much faster) and more reliable.
                        7" Lilliput LCD
                          @Craig This version will support D-link USB radio
                          This version does not have DB support .
                          @antimatter : on click on ETA & Dist Remaining will give a void feed back
                            I see. good
                            I cant wait to see the rest of your program and to start working on some skins for it
                              Understand I correctly: SQL for a CAR-PC Software?!
                              Sorry, this ist most overkill!!! Whis CAR-PC HW and OS will be bear?
                              NO, i will not install a SQL, or MSDN Databas ONLY for a DB for some Musicfiles ....
                              Slow down Guys! Winamp works very fine without SQL, MS-Mediaplayer also.
                              Mediacar works very fine with Winamp, also no SQL ...
                              Do not exaggerate please
                              Regards
                              Oliver
