Voices Navigation Interface
  • Voices Navigation Interface
    I wanted to post with my recomendations on a menu interface for mainly SilentAdmirer but also for everyone elses input.
    SilentAdmirer has tasked me with creating a well thought out interface for Voices.
    After installing Routis 2004 (and being very pleased with it by the way) and looking at a few other Navigation packages i realized that the interface that VOICES needed had to be pop up menu driven. For instance look at these screen shots of routis
    Notice the small unobstrusive menu button on the lower left
    There should be a button like this for VOICES
    Then a Pop up Menu follows with large easy to read skinnable buttons (as I invision it for Voices)
    Then when you click on each buttin a series of Options follow as below
    Not all of the information or options will be the same but it will definatly be close...easy to navigate and structured. I think that there is a reason that every navigation application has used this method... becasue it works
    What do you guys think?
    Pictures curtisy of MikeH
    thanX antimatter will start working on it rite now.Lets see what I can do about it
    Satish
    VOICES Status : Rework in Progress [||--------](20%)
    Preview Version at http://voices.techworldonline.com
      You may want to evaluate the way that your skinning is done aswell . Percent as opposed to pixles is supporsed to be a lot easier to work with when having an interface with multiple variations in resolutoins (as is all applications)
      Elaborating on the menu idea and looking at your current skin I like the Full screen function and the ability to make the map take up all of the screen.
      I think that the The full screen function should toggle from full screen map mode to split screen with the driving instructions. By taking away the menu that slides up from the bottom and making it a pop up menu (like in the pictures) I think that it would definitly simplify things.
      We should come up with the a set of 6 or so general buttons and place all of the items within the property pages of the repective categories.
        Have you this tested also on a 7" Display in your Car with a distance from for instance an arm length between eye and display? If you can read then the Button, without eyeglasses, and it on a Touchscreen also hit, it is large enough
        Regards
        Oliver
        http://picasso.zoffi.net
          Have we tested what? We are designing this with the touchscreen in mind and I ahve a 7" touchscreen for beta testing as does most people here.
            Here is the breakdown of the menu driven options that are in Routis/Iguidance. Customize these to the options that you have available in the Voices Nav App. I have insicated with italics the options that I think would apply with Voices and bolded the main menu buttons.
            Destinations
            Address
            Intersection
            Points of Interest
            Favorites
            Recent
            Route Options
            On/Off Buttons for Quickest/Shortest/Local/Major
            Reduce Turns enable/disable
            Toll Rodes enable/disable
            Carpool enable/disable
            Speed Alert
            number pad to enter in max speed
            checkbox to enable/disable speed alert
            Volume
            Mute button
            Test Button
            Volume Slider
            Map Options
            Show POI icons
            Map view 3D positions
            Map View Heading Up
            Map View Heading North
            Record
            Save your location and Route
            GPS Info
            Pop up screen with satilites locked/Longitude/Latitude/Alt/Speed/Compus
            I posted this information as a guide incase you havn't seen Routis or Iguidance.
            Cheers
              I agree about pop up menus, tomtom works on the same.. but it doesnt have a menu button.. you just tap the screen and the menu appears
              Follow me on Twitter
              http://www.FreeICE.co.uk
                I've been using Routis so I have a couple of suggestions that I think Routis lacks. Overall I think Routis is a very touchscreen friendly application, it's more features I'm thinking of.
                1. Routis has a box that displays your toute to a destination. It allows you to highlight each road. It would be great to be able to highlight the road and toggle it for avoidance. It gets dropped into a new window listing avoids. You can then on the fly move it from avoids and have it reroute. This is for when there's a traffic jam or accident and you want to hop off the highway to get around it then get back on the highway. So, this is partially interface and partially a new functionality.
                2. It would be nice to have speed displayed somewhere in the top or bottom bar that show your current street and your next street to turn at (rather than have to have the whole GPS data info box pulled up). There's plenty of room for some data in these bars.
                3. Around the edge of the map, there is an arrow showing north (if it's set to rotate). I'd also like one to show the bearing of my final destination in case I'm ignoring the route suggestions and just want to try to head toward my goal (maybe it already does this, but I don't see it).
                Ok, so I guess most of this is functionality but they all have GUI components . I've only used Routis and Mappoint so I don't have anything else to compare it to, but I really like the Routis interface and the way it minimizes the menus to use the full screen for a map.
                  Good comments
