RR and EWF with HORM
  • RR and EWF with HORM
    Hi, after search all forums thereīs something that still confuse me:
    Has anybody RR (installed in c:with EWF) saving playlist, .ini files.. (to other writable partition) and resuming from last song with EWF and HORM enabled?
    In that case: what itīs the good config. for rr.ini ? (I asume it will be HIBERNATERELOAD=TRUE and HIBERNATEAWARE=TRUE). Thanks
    Anybody?
        I'm trying to do that same thing write now but I can't get EWF working. Do you have your EWF files? If you're willing to share then I will give it a shot tonight.
          Please rephrase what you were trying to ask.
          New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
          SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
            I followed this threads:
            http://www.mp3car.com/vbulletin/winn...lar-winxp.html
            Here you are latest tutorial for EWF and HORM:
            http://www.mp3car.com/vbulletin/winn...tructions.html
            Attached 2 .rar (for upload limits) with ewf files I used.
            masch, what I trying to say is that I have been working with EWF and HORM in my system. When you have HORM active, you always resume from the same image, and returns always to the same song position.
            I think last RR makes possible to save playlist or .ini files before shut down and resume loading it (HIBERNATERELOAD=TRUE).
              If you have set RR as HORM enabled, when you shutdown(properly), it saves the resume.ini file to the RR folder (and tells EWF to commit that one file)
              MySpace!
                I will check everything and try another time, Thanks.
                  Checked And Still No Working. Any Idea??
                    Ok, after several probs this is what I found: Without ewf installed on my Os, RR detects shutdown from Xp, and saves resume.ini. With ewf inside, RR makes nothing, even resume protocols (phoco is not reloading bt conections like without ewf).
                    Next step: try with other ewf files.
                      Tested with ewf files from XPeSP2FeaturePack2007.iso
                      Still the same.
                      Even tried to "make just horm only" http://www.mp3car.com/vbulletin/winn...horm-only.html; and resume.ini not saved.
                      On debug.txt no shutdown detected
                      Please, Can anybody shot me?
                        you shouldn't be using RR on an EWF partition. If it's on an EWF partition, RR can't edit/create any files that will remain on the disk upon shutdown.
                        To get around this, I made 2 partitions on my CF card. I put the OS and enabled EWF on one partition, and I put the programs on the second partition
