Soudproblem in RR
  • Soudproblem in RR
    I have a problem with Roadrunner.
    It is installed on both desktop pc and the cpc, the both have an onboard soundcard.
    In the desktop i can select all exits of the sound such as: All lines, master volume, wave, sw-synthesizer, front, subwoofer, center, etc.
    On the cpc: Alle lines, master volume.
    At the radio section: desktop pc: disable, wave, front, cd-speler, etc
    Cpc: disable.
    The soundcard works fine in windows, i can select everything, mute, change volume, you name it it works. But in RoadRunner its a different story
    The cpc specs:
    - mobo commell 673 ns http://www.commell.com.tw/Product/SB...#Specification
    - os: win 2000 prof.
    - Sound driver realtec on mobo: http://www.realtek.com.tw/products/p...=4& ProdID=42
    I have tried all the sound-drivers i could lay my hands on, tried winamp 2.95 ,5.14, 512, 524, 535.
    RR 2006 until the last one i could get. I even tried copying the roadrunner from the desktop to the cpc.
    Somhow Roadrunner doesn’t seem to see there is a soundcard on the pc. Is there a file were i can let roadrunner know there is a soundcard, and where to find it.
    The simple solution would be to install a soundcard, but i don’t really have the space for is (see my install)
    Cold weather mobo list: Copy the list and add your board
    my hidden screen in action (youtube) , the worklog , RR Volvoskin
    It should work the same way on both machines, but different sound cards do work differently -- since you already tried multiple sound card drivers, let me ask you this: are you by any chance running Windows Vista on your carpc ? cause that would be your problem right there.
    If not, please add this to RR.INI:
    debugmode=true
    then run RR and post the debug.txt it will create in RR's folder so I can look at it.
    Ride Runner RR's Myspace
      debugmode=true
      No, on both the desktop and cpc windows 2000 prof.
      on the cpc i run servicepack 4 (driver soundcard needs it).
      yesterday i have upgraded it to the latest win 2000 then the os is exactly as the desktop.
      Startup is effected, it costs me 20 seconds extra ,
      But first the sound,
      I' ll try the debug function and post it, thanks.
        roadrunner sound
        under the rr config you could try souncard = 1 or souncard =0, or even =2? have you tried that?
          No haven't tried that, gone trie that tonight, but it sounds prommesing
          tried, didn't work
            the debug file:
            3-4-2007 20:33:15: Start -- Version: 12-11-2006
            3-4-2007 20:33:15: Winamp window not found.
            3-4-2007 20:33:15: Shell: "C:\Program Files\Winamp\winamp.exe" /CLASS="Winamp v1.x"
            3-4-2007 20:33:15: Sim.WMSGs: 1
            3-4-2007 20:33:16: Enter Exec: False, menu.skin, , False
            3-4-2007 20:33:16: Que Exec: True, menu.skin, "ONSKINSTART", False
            3-4-2007 20:33:16: Executing: ONSKINSTART
            3-4-2007 20:33:16: Leave Exec: False, menu.skin, ONSKINSTART, False
            3-4-2007 20:33:16: Que Exec: True, menu.skin, "ONSONGSTART", False
            3-4-2007 20:33:16: Executing: ONSONGSTART
            3-4-2007 20:33:16: Que Exec: True, menu.skin, ONLINE, False
            3-4-2007 20:33:16: Executing: NLIN
            3-4-2007 20:33:16: Leave Exec: False, menu.skin, NLIN, False
            3-4-2007 20:33:16: Sim.WMSGs: 1
            3-4-2007 20:33:17: Sim.WMSGs: 1
            3-4-2007 20:33:18: Sim.WMSGs: 1
            3-4-2007 20:33:24: Enter Exec: False, menu.skin, "SKIN", False
            3-4-2007 20:33:24: Que Exec: True, menu.skin, "SKIN", False
            3-4-2007 20:33:24: Executing: SKIN
            3-4-2007 20:33:24: Leave Exec: False, menu.skin, load;skin_browser.skin;skin browser, False
            3-4-2007 20:33:26: Enter Exec: False, skin_browser.skin, "SENDMSG;FreeDrive;QUIT||EXIT||EXIT", False
            3-4-2007 20:33:26: Que Exec: True, skin_browser.skin, "SENDMSG;FreeDrive;QUIT||EXIT||EXIT", False
            3-4-2007 20:33:26: Executing: SENDMSG;FreeDrive;QUIT
            3-4-2007 20:33:26: Que Exec: True, skin_browser.skin, "EXIT||EXIT", False
            3-4-2007 20:33:26: Executing: EXIT
            3-4-2007 20:33:26: Que Exec: True, menu.skin, "EXIT", False
            3-4-2007 20:33:26: Winamp window not found.
            3-4-2007 20:33:26: Shutdown
            the line with shell doesn't epear in the desktop, that one also says a lot of times, can't find winamp
              update to latest win 2000 update din't make any differnce
              in the volume controle in windows it says on the bottem line
              desktop: Realtek AC97 Audio
              cpc: Realtek HD Audio output
              i am now triing to see if there is somthing in the rr.ini file to change,
              hope you can make somting of the debug file.
              there is also a file hw.txt, could it be in that files?
                reduce the preamp settings and any audio boost settings and try again
                My Nissan 200SX @ Silverstone
                NOW SADLY WRITTEN OFF!
                My Car's spec list + pics
                Stealth CarPC fab'ing...
                  from this debug file it seems there's something wrong with your windows mixer.. it's like it's not present at all otherwise it should be displaying the information about the audio lines available (which are none right now).. I don't know what you'll have to do to fix it, but I can tell you that this is not a problem with RR. I'm pretty sure that re-installing windows and the drivers would solve it, but maybe you want to try something else first... if you doubt me, I would invite you to install some other front-end (i.e. MediaCar, MediaEngine, Frodo, etc) and see if it works. It's possible that if the front-end is DirectX based (StreetDeck, etc) it may work simply because it may handle the mixer differently through the DirectX interface.. but it wouldn't change the fact that there's something wrong.
                  Originally posted by rijk View Post
                  the debug file:
                    The board already had a problem, no sound, send it back to the supplyer and got a new board. I also use a flashdisk, where for some reason win XP doesn't want to install, win 2000 doesn't make a problem off it.
                    The mixer does show and work in windows, but i'll format and reinstall.
                      no luck, formatted the disk, reinstalled win 2000 pro, installed drivers, installed winamp, installed RR. stil won't work
                      I have noticed that in winamp:
                      When i start up winamp, options, preferences, plugins, input, midiplayer, device.
                      Then the desktop shows : realte ac97 audio.
                      the cpc doesn't show the soundkart.
                      Might it be posible that the problem is in winamp. And is it then possible to add that line in the regiser?
                      Or is it possible to us rr without winamp en replace that with the windows soundcontroler?
                        Succes
                        I have tried everything with win 2000 and the soundcard just wasn’t there in RR.
                        Then i tried the same in XP en the soundcard was there. But this was on the SATA disk, and for the os i want to use the flashdisk.
                        But XP just wouldn’t install on it.
                        But now i knew the mobo was good and the driver was good
                        So it was back to how to get xp on the fashdisk.
                        Finely i used ghost to copy the xp sata disk to the flash disk.
                        But all it showed was the welcome sign and then it stopped. This was probably because the flashdisk is ide.
                        Then the idea was to use an ide disk to install xp and copy that to the flashdisk. But sins the cable on the mobo only has one normal and one notebook ide connection, i needed something for the cdrom.
                        I tried the usb dvd, and that worked. As a sort of joke i had xp repair the installation on the fashdisk. It wasn’t working, so nothing to lose.
                        And it worked.
                        Xp is now installed on the flasdisk.
                        The mobo boots in 27 seconds, any suggestions what to strip from XP to make it quicker.
                        Or is it a good idea to use the standby mode (i use the m2 for power). The flashdisk doesn’t much power, and the mobo, i don’t now “yet”
                        http://www.transcend.nl/Support/DLCe.../TSxGIFD18.pdf
