Radiomode resets to 0 if using RRconfig
  • Radiomode resets to 0 if using RRconfig
    Has anybody else experienced the RoadRunner config tool settings the radiomode back to 0 each time it is run? I'll set it to 7 in the rr.ini file and then later use the config tool to switch skins and the radiomode will be back to 0. I was chasing this dang radio problem all over the place. I'm trying to get the commands setup up in my skin to work with the Silabs radio, I would have it working one minute, take a look at another skin, and then it would stop.
    Current in car setup
    Epia m10000 with XP, current roadrunner and drivers.
    Current test setup
    IBM X40 tablet, Xp tablet edition, current roadrunner and drivers.
    It does it on both computers.
    thanks
    Mike
    Yes is Been Known For Another People As Well, I'm One Of Them.I Use A Simple Autoit Script To Make Sure I Keep This Setting, I Think Is Possible With The Command "WRITETOINI" Also.
    BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
    RRTube ==> [View/Download Youtube Videos]
    WifiMan ==> [Wifi Manager]
    RRec ==> [Audio Capture]
    If You Want To Be Given Everything, Give Everything Up ...
    Bird York -- In The Deep --
      Yep, used to happen to me. El Camino helped to fix it with a script he made: http://www.mp3car.com/vbulletin/road...ated-rr-2.html
      OLD SYSTEM (DEAD)
      Intel D945GCLF2 Dual Core ATOM
      Lilliput 7" 629GL 2008 LED Backlight
      BU-353 USB GPS Receiver / iGuidance / IGO8
      M2-ATX Power Supply
      RideRunner Front End / Various Skins
      Windows XP SP3
        Here is an updated RRconfig.exe
        Added Radiomode=6 (RadioShak)
        Added Radiomode=7 (Silabs)
        Next in line: RRMedia v2.0
        DFX 5.1.1 Skin
        Appstore Link
        My RideRunner Plugins
        RRMedia
        RRExtended
        DFXVoice
          nice!!!
            Thanks.
            OLD SYSTEM (DEAD)
            M2-ATX Power Supply
            Windows XP SP3
              Thank's Blue,that's just what i was after.
              Cheers.
              P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
                Thanks Man! That solved one headache, about 9 more to go.
                One more question, how do you get the radio skin to start with a freq. other than zero? I've copied some buttons from a working skin to my skin file, but my radio skin just shows feq. 0 and is AM. I've looked and there isn't a button command that I can find that switches between bands AM/FM. According to one of the threads I found, RR knows which band to use based on the freq. chosen. I guess because it is starting at 0, that RR thinks it's AM. I've got presets in the radio.ini file with a working FM freq first but still nothing. Is there a thread somewhere that details setting up the radio part of RR? Thanks in advance!
                Mike
