nRoute SKIN for RR and MC2.0
  • nRoute SKIN for RR and MC2.0
    Hi!
    I made a skin for nRoute. It has some problem but it works..
    the problem...
    sometimes the Zoom menu is lost focus (RR) i try to correct it.
    If you find an City by name the DEL button is not work correctly because nRoute is open an dropdown menu> you must press it twice i try to correct it but i can't
    It works only an ENGLISH version of nRoute of course you can change the voice file ...
    the whole skin file : http:/medit.uw.hu/20070529.zip
    i hope so you can use it...
    GuMiSZu
    Englishlessness :(
    Looks good....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      Hi I just can get it to start. Where should I put nRoute? I installed it on default dir C:\Garmin\nRoute\nRoute.exe but it does not start.
      I put files from mc2.0 to skin folder. The skriptz folder is in C:\
      The Exec.TBL.ini and a.bat are in rr folder and NRouteSTART=0 is in rr.ini
      What am I missing?
        you could put nRoute anywhere, but set - up the RR external GPS and correct path...
        The OSK is not working right, update coming soon in this week or monday
        Englishlessness :(
          I would like to try your skin, but I can't download it.
          this link is not woking
          http://medit.uw.hu/EndNROUTE.zip
          please help, where can I download this nroute skin?
            I've updated the link
            Englishlessness :(
              The link doesn't work...
                IT WORKS
                now.... i forgot to rename it on server...
                sorry...
                Englishlessness :(
                  Thanks it is working: http://medit.uw.hu/20070529.zip
                    fyi - feel free to upload the files to our downloads section here.
                    You can find it in the nav bar at the top if you like.
                    Jan Bennett
                      any response... ?
                      Englishlessness :(
                        GuMiSZu:
                        I tried your nRoute skin, but unfortunately it did not work perfectly for me.
                        For example: there were some clicks on wrong tabs in Preferences window.
                        You have created some AutoHotKey scripts (they are in exe format) for complex "jobs" to remote nRoute.
                        It is a very good idea, but in my case it did not worked perfectly.
                        To investigate the problem I decompiled some of the exe files.
                        I found mouse movements and clicks in the decompiled scripts, but there were not any tab selection.
                        Part of the decompiled U-turns script:
                        Code:
                        WinWaitActive, Preferences,
                        MouseClick, left,  55,  248
                        Sleep, 100
                        I think it is not always the best way to use Autohotkey macro recorder for this tasks, because it usually uses mouse movements and clicks.
                        I have a solution to activate the appropriate Routing tab in Preferences window and uncheck U-Turns box without mouse movements.
                        Code:
                        SendMessage, 0x130C, 9,, SysTabControl321, Preferences
                        Sleep, 100
                        Control, Uncheck, , U-Turns, Preferences
                        Sleep, 100
                        Please try it, think it over, if you need my help please write me.
                        I left a message to you on the Hungarian pc2car forum too.
                          THX!
                          ill try it... i use macro recorder to make an exe...
                          where can i read the doc of autohotkey?
                          YESYES please help me.. i know my """solution""" is very simple and sometimes don't work correctly, but i don't know autohotkey....
                          Ducsi akkor ott magyarságosan megbeszélgetjük ok? az jobban megy ))
                          Englishlessness :(
                            How do I install the Nroute skin?
                            I downloaded the file. I unzipped everything.
                            I have put everything in the RR skin dir.
                            When I start RR I only see the default skin. Not the one I downloaded.
                            What should I change in Nroute?
                            I see there is a scripts.zip file. I unzipped that one to.
                            Where Do I have to put all the script exe's to?
                            How do I tell RR that I would like to have Nroute als deafult gps program
                              osa2: I have modified the skin, but it has only a hungarian install file.
                              I am going to create an english readme. You will be informed!
