Resolution/refresh problems
  • Resolution/refresh problems
    Ok, so I have what is hopefully an easy problem, and I'm just overlooking the obvious. I have RoadRunner up and running great (Love the program) with DigitalFX 2.0 (my favorite skin). It has worked great in the past, and on this same setup it has worked great, but I just recently closed it out and it changed the refresh/resolution on my monitor, making output to my 8' Lilliput impossible with an out of range error. I open the program, touchscreen loses it, close the program, the refresh/resolution reverts and everything is fine. Now, it was working fine with this same setup minutes before, it just started suddenly. I've tried rebooted, manually changing resolution and refresh, everything. Roadrunner/Digital FX does something, but when I looked at the config I couldn't find anything but the size of the monitor as an option. Any help would be much appreciated.
    Is this what you are looking for:-
    In the Skin folder is general.ini which includes
    OriginalWidth=800
    OriginalHeight=600
    ShowWidth=800
    ShowHeight=600
    The later two can be adjusted (within the limits of your graphics card !) as long as you know the original skin size.
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
