Dividing variables
  • Dividing variables
    How do i divide variables in RR? / sign is taken, so what symbol do you use? I am making a fuel log (just a table)
    date litres p per litre milage cost mpg
    variables are called
    datef namef pencef lastf nextf interf
    Date, litres, p per litre, milage are filled in with the numosk, cost is worked out by multiplying litres by p per litre - this works fine
    Code:
    B,549,115,105,28,"BYVAR;VMPAGE;EVAL;VMNEXTF01;$VMNAMEF01$*$VMPENCEF01$<<EVAL;VMNEXTF01B;$VMNAMEF01B$*$VMPENCEF01B$",
    I want to get mpg by dividing milage by litres and then dividing this by 4.5. If it was a / sign for divide it would be this (unless i made a mistake).
    Code:
    B,655,115,74,28,"BYVAR;VMPAGE;EVAL;VMINTERF01;$VMLASTF01$/$VMNAMEF01$/$4.5$<<EVAL;VMINTERF01B;$VMLASTF01B$/$VMPENCEF01B$/$4.5$",
    Please help if you can.
    Thank you
    Skins:
    /showthread.php?t=83814 (R.I.P.)
    /104373-golf-skin.html (R.I.P.)
    /106214-metal-spin-release.html(RIP)
    using own vw gypsy clone
    On 2nd PC: 1st one died.
    To make this much easier, Y don't you just use the Milage trip plugin??
    This is what it does, and keeps a log, like the one your trying to do *re-inventing the wheel??
    See here, I use it and it works great.
    http://www.mp3car.com/vbulletin/rr-p...nsumption.html
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      I know about that but cant test it it needs gps. I thought it would be simple to do it my way, I just need the divide symbol. Plus ive made the skin and it took ages.
      Skins:
        I guess no one know... or will tell me. Still hoping someone can help
        Skins:
          Why can't you use "/" ? I did and it works fine.
          Here's a line I use it in:
          Code:
          "EVALWINAMPVOL","EVAL;evalwinampvolvar;$TEMPigwinampvol$*255/100||SETVAR;evalwinampvolvar;$evalwinampvolvar$||SAVETOSKIN;evalwinampvolvar;$evalwinampvolvar$"
          Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
            For some reason it didnt work. Ill try again though.
            Skins:
              Ok found the problem... It now works. Thought the problem was because it couldnt use / as divide but it was something else entirely - some variables were named and labeled wrong and my maths was dodgy. LOL. Thanks for making me check again. If anyone wants the code, what it does and what i did with it just ask.
              Skins:
                Ok another question - is it possible to limit numbers to 2 dp only? I only need 2 decimal places in my output numbers, any more is pointless.
                One gives a cash value for cost, (so obviously more than 2dp gives 10ths of pence - useless)
                T
                he other gives MPG which only needs 1dp really (it isnt accurate enough to use any more) plus who cares about being something like 0.05 of a MPG out.
                Thanks.
                Skins:
