Problem after open rr with Wave Volume in Control Volume of Windows
  • Problem after open rr with Wave Volume in Control Volume of Windows
    Hi at all.
    I'm Italian, sorry for my english.
    I hava a problem with road runner. If i open rr and i close it the Wave volume in Control volume(open icons of sound in down-right of apllications bar) is set to 0.
    So i can't listen the sound of Windows, after i open rr!
    I post an image of problem when i close rr.
    thanks for support
    Don't know if this will sort it out for you but in RR config make sure that your volume is mapped to "Master Volume" and Not "All Lines"
      Hi, You must uncheck "mute winamp on rr exit" in rrconfig.exe
      See attach image.Bye
        Volume is mapped on Master Volume.
        Is it possible to uncheck "mute winamp on rr exit" in normal rrconfig,exe?because I don't have that version of rrconfig.
        thanks so much
          Add this to your rr.ini then.
          exitmute=false
          It should work.
            Thanks you very much Robterza.thanks thanks thanks thanks...
