Neither RUNQ or ONSKINSTART seems to work?
  • Neither RUNQ or ONSKINSTART seems to work?
    Hi all!
    ok, I was trying to get the W3bTracker software to autostart with RR and added both:
    Code:
    "ONSKINSTART","$RRPATH$\W3bTracker\W3bTracker.exe"
    and
    Code:
    "RUNQ;$RRPATH$\W3bTracker\W3bTracker.exe"
    to exectbl but none of them seems to work, it just won't start up the software with the skin!
    Might as well throw in a followup question aswell, the software itself is already skinnable but I want to make a button in RR to show it, so I'm guessing I have to make a new skin for it.
    I'm using the IPhone skin from CdR and was thinking of just making a copy of the freefone one to show the tracker window... just wanted to check if u think this menuitem looks about right:
    Code:
    &[email protected]\[email protected];freefone.skin;W3bTracker;$rrpath$\W3bTracker\W3bTracker.exe;W3bTracker&
    what does the part between the ;; right after shte .skin do and the last one?
    Swedish site for CarPC's
    http://www.bilpc.info
    First one is what RR will speak if there is no music playing.
    Second one is the window name to try and embed.
    As far as ONSKINSTART goes, I have no issue with that working. Although I must admit I don't use W3btracker
      Thanks!
      The link works since It starts the app and embeds it pretty nicely, but I still need to click it once to start the software...
      So I guess the "onskinstart" command is looking ok, strange but guessing I have something else interfering with it then!
        Originally posted by Naesstrom View Post
        Thanks!
        you should use this code:
        "ONSKINSTART","RUNQ;$RRPATH$\W3bTracker\W3bTracker .exe"
        good luck!
