iGuidance v2.1.2 into RR: Window problem
  • iGuidance v2.1.2 into RR: Window problem
    Hello
    I have install IG on my carpc all works fine, but when i open RR an click on GPS my IG software open in full window and hidden my RR interface.
    I RR.ini setup is:
    IGNative=true
    igautosw=true
    lastscreenswitchtime=3
    I had change patch to IG and set et to External.
    What can I try, thanks...?
    /Steffan
    Did you read the FAQ ?
    http://www.mp3car.com/vbulletin/rr-f...oadrunner.html
      MGD: Yir I have, but it still not work.
        Make sure you have those lines in RR.ini
        gpsmode=2
        gpspath=C:\Program Files\iNav\iGuidance\iGuidance.exe
        gpsname=iGuidance
          Okay I took your 3 lines and changes IGNative=true to IGNative=false now it works. Thank you many times MGD.
            I'll have to add a check for this too...
            Next in line: RRMedia v2.0
            DFX 5.1.1 Skin
            Appstore Link
            My RideRunner Plugins
            RRMedia
            RRExtended
            DFXVoice
              I have tried all the possible settings and for some reason it will not embed the i guidance 4 window.
              any suggestions?
                any suggestions?
                what is wont embed?
                open the program but not make it look like part of RR, or nothing happens at all?
                If the first, your window title is probably not correct. What is it?
                If the second, then your exe path is probably not correct. What is it?
                1.9in x 2.9in -- 47mm x 73mm
                  where i goto the gps skin from the menu, it loads the application iGuidanceUMPC.exe but it does not embed the window.
                  gpspath=C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe
                  gpsname=iGuidance
                    Could there be a problem, since I am embedding an app in another skin?
                      Anyone have any other ideas?
                        try running RRConfig and set iGNative=true....Click the checkbox next to it. Put this line in your EXECTbl.ini file
                        Code:
                        "GPS","LOAD;EXTERNAL_GPS.skin;Navigation;C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe;iGuidance
                        Then call it from the menu skin with "GPS"
