some music wont play
  • some music wont play
    I've registered my winamp.dll and i set my music types to .mp3,.wma and all my music still wont play any thoughts? Thanks, Drew
    1998 Camaro Worklog Starting over, New setup for 2010
    Does any music play ? did you by any chance register winamp.dll and then moved it somewhere ?? are you able to play the same files in winamp alone (outside RR) ?
    Ride Runner RR's Myspace
      i didn't move the dll. I can't play the files in or out of rr while i can play others.
        Just a stab in the dark here, but if you cant play them outside of RR, I would possibly, tend to thing, that is is not a RR related issue
        Sounds like you just downloaded some bad / corupt MP3's
        My Fiero Build Thread
          ok well then i guess it'd be a winamp issue since i ripped the cd's and they play perfect in window media player.. any ideas on that? they used to play in winamp. I'm using 2.95
            Just so we are clear, the CD's play fine, but not the rip'd MP3's do not. It just sounds like a bad rip for some reason, Is it a lot of mp3's or just ones on certain CD's that were ripped from?
            The more information you can provide, the better.
              Are they .mp4?
              Ampie Case
              256 MB DDR2 PC5400
              Xenarc 700TSV - VGA Monitor
              Intel D945GCLF Motherboard
              M2-ATX-HV
              2005 Honda Civic
                guess he ripped some cd tracks
                the ripped tracks play fine on WMP but not on winamp
                is that the question?
                you ripped it to .wma or .mp3? constant bitrate or VBR? wich bitrate?
                as john said, the more info, the better
                []s
                Tigra Clube Brasil
                  ripped as .mp3 at 192kBps
                  They work perfect on windows media player but not winamp.
                  I have version 2.95 and have downloaded it several times to make sure it's not corrupt and tried it on different computers without any problems. To top it off tonight i installed winamp 5.3 and it works perfect, but i'd like to not use it because of the performance side effects.
