Road Runner won't load music
  • Road Runner won't load music
    hi, I'm new here but I have been doing car PC's for about a year now.
    Anyways, I decided to change from MediaEngine to RoadRunner. The only problem is: Road Runner will not load my music. The only way that it will load my music is if I open up winamp first and start playing music through that. I have tried making a new playlist and tried to get it to play it out of that, but it still will not work. I really want to get this working because Road Runner has a lot of features that I would like to utilize. Thank you!
    SHisssssss
    Download RRConfig and set you music path. You need to tell RR wheer your music is.
      What about registering winamp.dll?
      Click here.
      First post, under Notes, first list item.
      For Sale: Carputer (CarPC) & RCA Y-Adapter
      Newsflash: Take a look at my unsold stuff above, thanks!
      Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
        Originally posted by MGD View Post
        SHisssssss
        i already set the path, but it still will not work. it works on my desktop when I test it, but not on the carpc. strange.....
          Click here.
          I'm not sure how to do that exactly. the instructions were difficult for me to understand. could you possibly explain it in a less technical way?
            Click here.
            If using the new config ver 1.0.0.0, there is no longer a need to reg it!
            Next in line: RRMedia v2.0
            DFX 5.1.1 Skin
            Appstore Link
            My RideRunner Plugins
            RRMedia
            RRExtended
            DFXVoice
              1-Make sure you're not using winamp LITE
              2-Make sure your path to winamp is correct in RRConfig
              Ride Runner RR's Myspace
                Click and download the file to reg and unreg dll, ocx easier.
                Regunreg file
                ````` _____||.\__
                .:.:.:.:.:.:;!_(o)______(o)'i
                TruckputerX - Vortech SuperCharger Vid
                TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
                  Hate to go here but...GET A CLUE PEOPLE. The new config alread does this!!!!
                  No need to reg anything, it does it every time you run it!
                  DFX 5.1.1 Skin
                  Appstore Link
                  RRMedia
                  RRExtended
                  DFXVoice
                    Did you specify file extensions in RRconfig?
                      I had the exact same problem after updating Roadrunner. My problem was that I was using RRconfig, the really old one. If you run the new Road Runner config that Blue Z made, it will register and fix it for you, along with other amazing things.
                      Here's the catch... the new Roadrunner config file is named "RR config.exe", the old one, which installs with Roadrunner, is "RRconfig.exe". Note the space in the filename.
                      It took me a while to figure out what was going on, since my shortcut was for RRconfig, and I thought that I was running the new one and actually I was running the old one. Maybe this isn't the way it is in your install, as things often go crazy just for me so that I feel like an idiot and look like a fool...
                        After I switched to the new config (KICKS ARSE BLUE) I had to select the audio file types that I wanted to play, then it worked fine.
                        Aron
                        New Ipad
                        Zapco DSP-6SL
                        Zapco Reference 360.4: H-Audio Soul, x2 right side
                        Zapco Reference 360.4: H-Audio Soul, x2 left side
                        Zapco Reference 500.1: JL Audio 10W3V3 Stealth box
                          Click here.
                          SHisssssss
                          Aron
                          tried both those things and it ALMOST worked! for some strange reason, i cannot have road runner hide winamp, or it doesnt work. If its hidden, it doesnt work. If its visible, it works! it isnt a big deal for me so im happy now.
                          One more question: how do I have road runner start on bootup? i dragged the shortcut to the startup folder in the start menu, but is there a way it can start up before windows loads? media engine had the option to make it the default shell, so im sure that road runner must have something like that.
                          Thanks a lot everyone!
                            Glad to see the config does what it does best, prevent less headaches( for you guys anyway..LOL)
                            I think that I'll stop in at the next meet Aron...
                            DFX 5.1.1 Skin
                            Appstore Link
                            RRMedia
                            RRExtended
                            DFXVoice
                              SWEET!!!!!!!!!
                              Aron
                              New Ipad
                              Zapco DSP-6SL
