using setvar with ||
  • using setvar with ||
    Just found ++ I'll try that....
    I need to set a variable to a value that contains multiple commands ( using ||). Can this be done using setvar? Here is the line from my autoit script:
    $rr.Execute("SETVAR;" & "CMDDISK" & $n & ";" & $CDCOMMAND & "||LoadList;" & $MyDrive[$n])
    Here is an example of what RR gets...
    SETVAR;CMDDISK3;AUDIO||LoadList;Z:\
    RR sets CMDDISK3 = AUDIO and then executes LoadList;Z:\
    Anyway I can use setvar to set a value containing ||?
    This does work if I set the value of CMDDISK3 in skin.ini, then do a skin reload....I really don't want to do multiple skin reloads.
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    try this code.
    Code:
    $rr.Execute('SETVAR;CMDDISK'& $n & ';' & $CDCOMMAND & '||LoadList;' & $MyDrive[$n])
    BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
    RRTube ==> [View/Download Youtube Videos]
    WifiMan ==> [Wifi Manager]
    RRec ==> [Audio Capture]
    If You Want To Be Given Everything, Give Everything Up ...
    Bird York -- In The Deep --
      The single quotes do the same thing and rr see's the || and assumes setvar is done and issues the next command. using ++ instead of || fixes the issue.
      MediaLaunch for RR
      Online Check for RR
      Locker for RR
