RR and Windows Fundamentals
  • RR and Windows Fundamentals
    Has anyone tried to run RR on WinFLP (Windows for Legacy PCs, http://en.wikipedia.org/wiki/Windows...for_Legacy_PCs) ?
    That's a version of XP that's made for running on low spec PCs. Strangely it's only mentioned once on this forum.
    I have not used it but from the specs it doesn't appear to be better than slimmed down version of XP that people normally use.
      looks like you'd be better off using Nlite or another similar utility to trim the fat in XP SP2.
        I have used TinyXP a few times in the past...
        *small install (200-400mb, if I rember right)
        *completely installs in like 8 mins
        *after installed, like 5-10 running backroung process
        Just Search..
        Next in line: RRMedia v2.0
        DFX 5.1.1 Skin
        Appstore Link
        My RideRunner Plugins
        RRMedia
        RRExtended
        DFXVoice
          Try a search for BulletXP. This is an Nlited version of XP that includes the wireless drivers, and is the most stable I have used of the stripped down xp genre.
          This has the lastsession.ini file included, so you can change the settings if needed and re-nlite. I used this method to replace the US locale/keyboard with the UK versions, and it works a treat.
          KPJUK
          M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
          DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
