Phoco volume disable and DTMF for number buttons
  • Phoco volume disable and DTMF for number buttons
    Hi guys,
    My phoco integration is almost done. Two things I can not figure out.
    1. Phoco must be controlling the volume instead of RR. The volume is way lower, is there a way to disable phoco and have RR control the volume on calls?
    2. When I push the buttons to dial I do not get the DTMF tones, is there a directory or something to put the wave files in?
    For anyone out there, if you have an ITX board, get a 2.0 USB high speed 480Mbps capable bluetooth dongle, get a PCI USB card that supports High speed 480Mbps USB and the voice will not cut out anymore, the person on the other end will hear you better as well. I have tested this with automated voice response systems with no issues, unlike the past where I had the old USB 1.1 dongles.
    Sound Stage
    Eclipse|MTX|Infinity
    1-I'm pretty sure this is a Phoco setting not to change the volume
    2-RR won't make the DTMF on itself but if you have wav files you can make them play with a simple command line wave player using the RUN command from each button.
    Ride Runner RR's Myspace
      Sure, you can edit the "PhoneCtl.Config.xml" located in the PhoCo installation folder, and delete or comment the line:
      <MainVolumeOnCall restoreVolume="True">20</MainVolumeOnCall>
      Optionally you can save a mixer preset with the volume level desired and rename it to
      "PHOCO.PST", so when a call is made or received this EQ preset will be loaded.
      _______________________________________
      Car installation 95% [■■■■■■■■■■■■■■■■■■■]
      Current project: Parking sensor USB interface
        Thanks guys, works well now
        Sound Stage
