RR Freezes and crashes...
  • RR Freezes and crashes...
    not sure what the problem could be, i havent had to much time to look at it, but im not sure if its with the skin or RR...
    so i am using LSX 2 with latest rr... now everytime i load RR it will run perfect for like first 2-4 min then it will freze. other things still work, i can CTRL ALT DEL and get outa it and restart... but everytime it will freze the max i had it on for was about 8 min b4 it froze...
    any ideas of what to check?!?! thanks!
    1-Try a different skin, see if it works for say 30 minutes without freezing
    2-set localdatacaptureinterval=0 in RR.INI then try it again on the same skin
    Depending on the case, you could install or remove ziplocator.dll from RR's folder, and/or verify you have the most current zips.dat file.. then check the version of RR by checking RoadRunner.exe file's date -- the latest should list September 30th (and previous versions have had issues with the zip code feature).
    Ride Runner RR's Myspace
      Ok so i tried both those suggestions u gave... and none of them worked... any other ideas?
        OK, REINSTALLED RR FROM SCRATCH... USING BMV SKIN... NOT WORKING AT ALL, LOADS for 6 seconds then freezes..!!!
        grr i have a big trip in 2 days i really need this :-D
          ALSO tried the ziplocator... no go..
            here is RR config
            Code:
            [General]
            winamppath=C:\Program Files\Winamp\
            hidewinamp=false
            launchpath=C:\Program Files\Road Runner\LAUNCH\
            startcommand=
            voice=false
            disableinternat=false
            exitmute=true
            showicons=false
            showextensions=false
            hidemouse=false
            hidetaskbar=false
            hidedesktop=false
            hidedots=false
            gpstime=false
            gpsusadate=false
            exitmode=0
            dateformat=MM/DD/YYYY
            timeformat=HH:MM AM/PM
            locale=0
            screentype=4:3
            debugmode=false
            enableclipping=true
            nozoom=false
            usegestures=true
            leavemousealone=false
            closeapps=false
            fastmode=-1
            usedualmon=false
            soundcard=0
            screenlimit=3
            mastervolmap=-1
            hibernateaware=true
            forcehibernate=false
            hibernatereload=true
            usbsound=false
            browsertype=0
            browserpath=C:\Program Files\Mozilla Firefox\firefox.exe
            usevoicecontrol=false
            usecar2pc=false
            fadeinvolume=true
            [Skins]
            skinpath=C:\Program Files\Road Runner\Skins\BMV2\
            nightskin=C:\Program Files\Road Runner\Skins\BMV2\
            transition=-1
            backgroundpath=To set path,Click --->
            [Gamma]
            gammamode=3
            gpsgammamodeoffset=0
            gammaday=0:0:0
            gammanight=0:0:0
            gammadaytime=1:00
            gammanighttime=1:00
            autogammamode=2
            autoskinmode=1
            [Preload Screens]
            preload=
            [Music]
            musicpath=C:\Documents and Settings\Administrator\My Documents\My Music\
            playlistpath=Click here to set path
            useid3=1
            showid3playlist=false
            showid3browse=false
            lazytag=false
            singleclickaudio=false
            noformat=false
            listnumbers=true
            listfollowssong=true
            resumemusic=2
            audiorepeat=last
            audioshuffle=last
            id3listformat=%title%
            id3browseformat=%title%
            titlesafter=-
            albumart=*.txt
            fadeimages=true
            audiofiles=.aac,.m4a,.mp3,.mp4,.wav,.wma
            visuname=!Winamp Gen!AVS
            scrollmode=1
            circularlist=false
            groupnumbers=false
            picspath=C:\Documents and Settings\Administrator\My Documents\My Pictures\
            [Radio]
            radiomode=0
            allowallfreqs=false
            userbds=false
            [XM]
            xmport=0
            xmlineinplugin=false
            xmtype=0
            singleclickxm=false
            xmformat=%station% %artist%
            [SIRRIUS]
            srport=3
            srlineinplugin=true
            srlineinpar=line://title=SIRIUS,srate=44100,bps=16,nch=2
            singleclicksr=false
            srformat=%station% %artist%
            [Video]
            videopath=C:\Documents and Settings\Administrator\My Documents\My Videos\
            mpcpath=C:\Program Files\Windows Media Player\
            videoautohide=true
            videohidetime=4
            builtinvideo=true
            videofiles=.asf,.avi,.mpeg,.wmv
            videoshuffle=false
            [TV]
            tvline=0
            [GPS]
            gpsmode=2
            mapmonkeypath=Click here to set path
            gpspath=C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe
            gpsname=iGuidance
            overspeed=55
            gpsport=15
            mappointmap=1
            mapcountry=United States
            mapcity=44060
            mapautozoom=true
            isunits=true
            usegpsserv=false
            gasfinderautorefresh=false
            mapvol=50
            [IG Native]
            ignative=true
            igautosw=true
            gpsonvoice=true
            pauseonvoice=false
            lastscreenswitchtime=0
            [Speed Att Vol]
            speedatt=false
            [Phidget]
            phidget1=0
            phidget2=0
            phidget3=0
            phidget4=0
            phidget5=0
            phidget6=0
            phidget7=0
            phidget8=0
            [4 Temps]
            tcomport=
            tempscale=c
            temp1=c
            temp2=c
            temp3=c
            temp4=c
            [Volt Meter]
            vcomport=
            [Phone]
            phoconodesign=false
            motophone=false
            phonelistspath=Click here to set path
            contactspicturespath=Click here to set path
            ringtone=Click here to set path
            smstone=Click here to set path
            maxcalllistentries=100
            phoconoincallevent=false
            connecthsp=1
            standardphonebook=0
            phonebooksencoding=windows-1252
            [Weather]
            cityweather=Mentor, Ohio
            weatherunits=USA
            weatherdegress=
            [Extra's]
              Can you add debugmode=true to RR.INI, run RR then ZIP debug.txt and post it here ?
              The first things I would try are:
              -Set srport=0 and see if it freezes
              -Set gpsport=0 and see if it freezes
              -Delete the screenlimit= line from RR.INI
                so it has to be gps sr or screenlimit... works fine without those...
                hmm
                let me try enabling 1 at a time
                  GPS working fine...
                  hmm /testing Sirius
                    hmm, works fine with Sirius.. what is that screen limit??
                      twice now i got
                      Run-Time error '9'
                      Subscript out of range then it closes.
                        screenlimit sets the maximun number of screens you'll allow RR to load -- this is a way of preventing RR from using too much RAM and a way of preventing RR from taking up too many resources (graphics, video memory etc) -- specially for computers/cards that are limited with those.
                        I recommend deleting that line and only adding it when you have some sort of problem as described above, and even then, it should be set to the highest number it has shown to work well with -- 3 is just the bare minimum for RR to work.
                          well it is the sirius that is causing it... i thought it was fixed but after 8 min or so it froze yesterday.... so not really to sure.. i got the sir-alp1 unit.. anyone know if its 12w or 5w to power it and what else to try?? also
                          sometime my list in RR vs WINAMP is off like the song names dont match and such, i notice mostly when i ADD a folder at a time...
                          lastly when i have AUTO switch on for night/day i get that subscript error... if you could give me some ideas for that too thanks!!
                            Check out thread, it @might@ help http://www.mp3car.com/vbulletin/road...-computer.html
                              For the sirius issue, you could have a bad cable or some interference causing garbage in the line, though, there are plenty of preventions in RR against those issues -- make sure you're running the 9-30 version.. may be you want to run a port monitor or try mitchjs's sirius application to see if it freezes up anyway -- it wouldn't hurt to switch the serial port used to rule out port/driver issue (specially if using a USB-Serial adapter).
