RX8 spinning car animation for you Guino!!!
  • RX8 spinning car animation for you Guino!!!
    I know its not much, but since I was in the process of making one for my TL as an intro to RR I decided to make one for you as a small token for your hard work.
    I looked up the RX8 and made one for you, thinking you might have good use for it. Maybe use is at as an intro to wow people
    It was made by taking over 500 screenshots from http://www.wheelenvizio.com
    and importing into flash.
    Of course I didn't sit there taking those screenshots.... I used a autoit script and let the sucker run for 2 hours taking screenshots and moving the mouse. lol
    If you have any request in changing it, let me know. I'd be glad to be of service.
    Brasil.. unido.. ja mais sera perdido!!!
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    what no Mazdaspeed 6 ?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
      I downloaded it, and it's really cool.. but somehow when playing it, it uses over 200Mb of memory on my machine -- I gotta try it on a skin to see if it works better.
      Ride Runner RR's Myspace
        Any chance you would be willing to share that autoit script?
          Yeah i see what you mean,just watching it in iexplorer took 472mb on my pc.
          P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
            how about adding this for an RX8
            well, I hope this posts ok. The text version is an animated Renisis rotor image. Lets see if I can post it from work.
            ~DS
              Yeah it has a LOT of frames, and it runs at 40fps =/
              I gotta try to trim it down to make it playable in the car. I'm probably one of the very few ppl who uses a fast carPC laptop so memory and CPU time is usually no issue for me.
              I'll clean it up a bit and post it soon, but you will need a program called SnagIT which takes the screenshot and saves the pic in a sequence. Also, you'll need flash to make it into a swf.
              I wish i had the time to do this for everyone but at 2hrs per sequence + time to make the movies, it becomes a bit of a hassle.
              EDIT:
              Here is the script I used:
              Code:
              ;Opt("MouseClickDragDelay", 30)
              MouseClickDrag("right",200,230,200,500,20) ;ZOOM
              sleep(50)
              MouseClickDrag("left",200,300,231,308,20)  ;TURN
              sleep(50)
              MouseMove(231,500)
              MouseDown("left")
              MouseDown("right")
              MouseMove(231,310)
              MouseUp("right")
              MouseUp("left")
              Sleep(100)
              exit
              ;TakePic()
              HotKeySet("{ESC}", "Terminate")
              $i=1
              $t=1
              while 1
              	ConsoleWrite(" " &$i)
              	;Click()
              	if $i<315 Then  ; FULL SPIN
              		MouseClickDrag("left",344,494,345,494,20)
              		sleep(20)
              		;TakePic()
              	Elseif $i>=315 and $i<394 Then  ;79
              		exit
              		If $i>=324 Then ; 72
              			MouseClickDrag("left",344,494,344,495,20)
              			sleep(20)
              		EndIf
              		sleep(20)
              		;TakePic()
              	Elseif $i>=395 and $i<472 Then ;78
              		If $i>=416 Then ; 56
              			MouseClickDrag("left",344,494,344,493,20)
              			sleep(20)
              		EndIf
              		sleep(20)
              		;TakePic()
              	Else ;53 more
              		ConsoleWrite("start back zoom in")
              		MouseClickDrag("right",344,494,344,510,20)
              		sleep(50)
              		;TakePic()
              	endif
              	$i=$i+1
              	if $i>508 then Exit
              wend
              Func Click()
              	MouseClick("left",76,523) ;try again button
              	Sleep(1500)
              EndFunc
              Func TakePic()
              	MouseClick("left",609,527)
              	Sleep(7400)
              	ControlClick("SnagIt","Capture",5315)
              	Sleep(2500)
              EndFunc
              Func Terminate()
                  Exit 0
              EndFunc
              My TL CarPC ver2
                yeah what I do is i unload the movie in my flash code when its over so it frees up all that memory
                It was mainly to be used on my next version of fsr.
                I will give u a version later on that the movie will unload itself at the end so you can use it.
                My TL CarPC ver2
