RR 11-02-2007 ... Suplements & Fixes ..
  • RR 11-02-2007 ... Suplements & Fixes ..
    NOTE: The Websites are not updated but the files are in place!
    In this version:
    -Added support to transparent iLists
    -Added support to poll playlist paths directly from Flash
    -Added support to poll label info directly from Flash
    -Added LOADLIST support for VIDEO player
    -Added support to load M3U files in VIDEO browser
    -Added OSKTEXT command to set text on OSK/NUMOSK
    -Added command to wait execution of commands from Flash
    -Improved LazyTag to work with audio browser
    -Fixed Hibernation issue with iLists
    -Fixed issue with sel colors and tag display in TEXT MODE iLists
    -Fixed issue with unselected text color of Custom Lists
    -Fixed issue with CUSTOMCL not auto-refreshing
    -Fixed issue with ShowExtensions option in iLists
    -Resumecheck of 30 seconds without updates instead of 5
    -Updated Web Plugin to work with "RoadRunner" in the .skin header
    Notes:
    -Please check changes in skin commands.txt
    -I will be traveling for work till the 21st, so don't expect to see me around (much) until then..
    There's always more to come.. Thanks for your support,
    Guino.
    Ride Runner RR's Myspace
    Man another update, that's great.
    BTW, I haven't have time to update my carPC. I'm still using the version that is 4 release old
    Probably because I'm still happy with that version.
    Great job Guino. If you happen to come to SoCal (LA), let me know. We can go out for a drink even I don't drink .
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
      transparent iLists!
      wasnt expecting those THAT quickly!
      2005 Nissan Xtrail
      DFI 855GME-MGF - Celeron M 1.4GHz - 256Mb RAM - 200Gb SATA HDD - OPUS 150w - Xenarc 700TSV
      worklog
        Have a safe journey mate
        and thanks for another release...... I'll get the Help file updated in the morning.
        cheers
        KPJUK
        M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
        DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
          Indeed...Guino has easily secured his place in open source car computing history
            Man, this is great news!!, as always thanks a lot guino.
            BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
            RRTube ==> [View/Download Youtube Videos]
            WifiMan ==> [Wifi Manager]
            RRec ==> [Audio Capture]
            If You Want To Be Given Everything, Give Everything Up ...
            Bird York -- In The Deep --
              Thanks alot guino. Will try the new release in a few mins and check if resumecheck-feature works for me .
                This is not really a "bug" but I've noticed that since version 9-30, RR doesn't populate winamp.m3u with the full song list on the !SELECT command, only the folder list.
                What I mean is that, for example, when executing a !SELECT command on "FolderA", this is what RR returns in winamp.m3u.
                D:\Media\Music\FolderA\Folder1
                D:\Media\Music\FolderA\Folder2
                D:\Media\Music\FolderA\Folder3
                as opposed to this (as RR used to do before version 9-30)
                D:\Media\Music\FolderA\Folder1\song1_1.mp3
                D:\Media\Music\FolderA\Folder1\song1_2.mp3
                D:\Media\Music\FolderA\Folder1\song1_3.mp3
                D:\Media\Music\FolderA\Folder2\song2_1.mp3
                D:\Media\Music\FolderA\Folder3\song3_1.mp3
                D:\Media\Music\FolderA\Folder3\song3_2.mp3
                RR still works fine (like I said it's not a bug) but I have a script that sorts the song list (winamp.m3u) by date and the script doesn't work anymore because winamp.m3u doesn't contain the full file list.
                guino, is there any chance you could take a look at this? Thanks.
                iGMon - Integration between iGuidance and Road Runner
                CFX - Skin for Road Runner
                  This is not a bug as much as it is an improvement.. the latest RR versions don't depend on the m3u file to intermediate the integration. I can help you to easily make a command that makes winamp write the winamp.m3u file so you can load it -- Or you can simply execute "SAVELIST;$winamppath$winamp.m3u" from your script and you'll have the file as well.
                    I've updated the release ZIP files on my site to include a fix to the built-in player that was broken... gotta travel now..
                      I'll try that. Thanks, man.
                        So far so good with the latest build. Thanks!
                          Ummm.....not to pick, but internal video still no worky.............
                          Leonardo Da Vinci
                            do me a favour.. run an ooold RR version 2 releases back and see if the video is working there.. if it is not then it is not RR, download a codec pack like ffdshow or something and try again. really can't imagine anything else? R U using a striped down XP or a full copy?
