no hdradioport in rr ini
  • no hdradioport in rr ini
    This my be a dumb question.
    According to the posts I have read, I must change the value of hdradioport
    in my rr.ini file.
    This value is not displayed in my rr.ini.
    Also is there a updated guide for running the directive hd radio nativly in rr?
    Any help would be appriciated.
    There is no guide that I'm aware of. The HD Radio setup in RR appears to be fairly new. You'll need to manually edit the rr.ini and add the hdradioport setting into the radio section.
      this is correct.. just use a text editor and manually enter it.
      Live mp3Car Facebook Chat
        This is all the guide would be:
        -Make sure you have .NET 2 installed (for the HD Radio to work)
        -Run runme1st.bat
        -Set radiomode=8 in RR.INI
        -Set hdradioport=X in RR.INI
        if it doesn't work, test with the HD Demo software from mitch.
        Ride Runner RR's Myspace
          -Run runme1st.bat
          That would make a great "readme" file for the HDradio folder...............
          (just put it in mine)
          Cheers
          Leonardo Da Vinci
