Please explain gamma settings
  • Please explain gamma settings
    Originally posted by vladcarpc View Post
    Hi,
    I have a Lilliput 8" Wide Model 889GL-80NP/C/T, using RR and it's built in gamma control.
    At night, the brightness of the screen is still too high.
    It is not secure. People from other cars or pedestrians can notice the screen very easily at night.
    So, what settings are you using in your gamma configuration? Or what else are you configuring or doing to reduce screen brightness at night?
    PS: At day normal or high brightness is important.
    Thank you
    Above is a question from another member that didn't get any response in the monitor forum which i'm also interested in. I'm posting it here in hopes of getting a better response.
    Basically, the monitor (8" lilliput 889GL) is too bright at night even with the normal "default" reduced gamma. Would like to know how gamma works and what settings to change to get it darker.
    I (we) know there's a gamma setting in config; just don't know how to accomplish the above.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
    To make it darker you want to make the colorls farther away from zero on the negitive side. default is -50, so try -75 ect..
    what this does is changes the brightness of each color up or down, although many argue that dimming by using gamma doesn't do as good job as a reduced backlight. The reduced backlight is a much better resulting dimmed picture, but w/o the know-how, time, effort...ect the gamma route is just easier to use, it just doesn't give as good results...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      Thanks ZX3, another question if i may: which take presedence, the gamma specified in general.ini or the one in your config? Do they interact in any way?
      OLD SYSTEM (DEAD)
      M2-ATX Power Supply
      Windows XP SP3
        The skins gamma settings (from the last skin loaded) should take over if they exist, otherwise the config ones are used.
        Ride Runner RR's Myspace
          Thanks. At -80 (the max you can go?) it dimms considerably, much better than before.
          Now i got to keep searching to see if i can find how to make it come out of dimm when the screen is touched (to make changes in playlists and such) then return to dimm after some idle time..
          OLD SYSTEM (DEAD)
          M2-ATX Power Supply
          Windows XP SP3
            Could be done with the idle skin command only if the gamma setting were able be be set/changed on-the-fly.
            Unless I'm wrong...
            DFX 5.1.1 Skin
            Appstore Link
            RRMedia
            RRExtended
            DFXVoice
              IDL,30 GAMMA
              wouldnt this work
              Idle 30 seconds then gamma
              New Age Garmin - Skin for RR
                IF the settings in the skin are messing with the settings in the control. What is the best way to fix this? What is the best way to remove the settings in the skin general file?
                  Somebody correct me if i'm wrong but i think if you set these all to 0, the settings in config will take over.
                  GammaDayRed=0
                  GammaDayGreen=0
                  GammaDayBlue=0
                  GammaNightRed=0
                  GammaNightGreen=0
                  GammaNightBlue=0
                  OLD SYSTEM (DEAD)
                  M2-ATX Power Supply
                  Windows XP SP3
                    This is my General.ini
                    OriginalWidth=800
                    OriginalHeight=600
                    ShowWidth=800
                    ShowHeight=480
                    XPosition=0
                    YPosition=0
                    All the rest for the gamma is in rr.ini
                    [Gamma]
                    gammamode=2
                    gpsgammamodeoffset=0
                    gammaday=0:0:0
                    gammanight=-50:-50:-50
                    gammadaytime=6:00
                    gammanighttime=18:00
                    autogammamode=0
                    autoskinmode=2
                      You would also need to set the gamma to use the external app, either gamma pannel or Gamma Control...if your using that to control your gamma( you didn't really specify).
                      DFX 5.1.1 Skin
                      Appstore Link
                      RRMedia
                      RRExtended
                      DFXVoice
