RR Files
  • RR Files
    Hi Guys
    Well i am facing a funny problem with RR installer files.
    I did a fresh install of RR.
    And now some files are missing and also get a strange prob of NO MP3 in folders. ( so searched here and got the solution )
    Now I am not able to LAUNCH RRconfig from the Setting TAB in the DFx skin....
    While this was ok when i had the same ver of RR instaslled the first time
    SO why is it a few files go missing and even the config becomes difficult like i have to chose the FILE TYPE ( mp3 ) for the music
    can some 1 help pls
    thanx
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
    Originally posted by vicky_obee View Post
    Hi Guys
    Some files are missing?? As in like which files?
    Couple of things...
    1. R U using the latest config (mine)?
    2. Did you see the DFX thread about changing the skin file for the newer config (it was setup for the old one)?
    With the music file types, you either select all of the types you want or select none and RR will use its default music file types.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
      Either in the file types you want rr to display or make sure that this line doesn't exist in rr.ini
      audiofiles=
      Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
        Yes i am using the file made by you.......Blue ZX3
        OK deleted the entry ""audiofiles="".....
        Yooo man works now... but wonder where i missed out and how did i get this entry and that to blank
        thanx guys
        2.6 GHz; 1 Gb Ram
        120 Gb Laptop HD
          That was a bug in the last config version, unless that was something that I fixed and is in the pending update..
          DFX 5.1.1 Skin
          Appstore Link
          RRMedia
          RRExtended
          DFXVoice
            Out of cusiosity, and to hijack a bit, is there anyway of getting the config program to stop defaulting to *.jpg and *.txt for the album art? I use the mp3art.dll plugin, and everytime I make a change in config, I have to make sure that I clear them.
            "the universe has a way of balancing itself"
            http://i15.photobucket.com/albums/a3.../Webbanner.jpg
              please also note this in the config thread so in the next update I won't forget about checking on this too...
              Thanks,
              DFX 5.1.1 Skin
              Appstore Link
              RRMedia
              RRExtended
              DFXVoice
