AutoIt Detecting when Road Runner closes
  • AutoIt Detecting when Road Runner closes
    I have a script that poll's RR for information. I have multiple checks in the script like the following:
    if ProcessExists("RoadRunner.exe") = 0 Then Exit
    I have this the line above all lines that poll info from RR.
    The problem, is when RR closes, The Road Runner.exe process can remain in the task list for up to 4 seconds. Thus, I get a nasty error from the script that the object has failed when I close Road Runner. (The window handle also remains active till RR completely shuts down, I tried that as well)
    The script polls information every 1 second, and I do not want to have to put a wait for 5 seconds before it polls info from RR.
    Is there another way, with AutoIt to more reliably tell when RR is closed or in the process of closing?
    I did find this:
    Opt("RunErrorsFatal", 0)
    Which disables error reporting, but only on run & wait commands, and not other types of errors.
    The script is pretty straight forward, and solid, so I am not opposed to turning off errors completely for the script, if someone knows how.
    My Fiero Build Thread
    which object are you using in the script that is giving you the error ? is there no way to check if the object has closed or is still valid ?
    Ride Runner RR's Myspace
      I am using the following code, interacting with RR's SDK:
      $rr=ObjCreate("RoadRunner.sdk")
      $rr.Execute("SETIND;CUSTOM_CdInsert;OFF")
      I have found no way, as of yet, to check if the object is still valid, without actually using it.
        the way i handled this is to tell my script to set a variable to "1" in rr once the object is created then check the status of that variable before i run any .execute commands. My exectbl.ini tells rr to set the variable to "0" before rr closes. I no longer have those errors
        Live mp3Car Facebook Chat
          Maybe try using "IsObj($rr)"
          ie
          if IsObj($rr) Then $rr.Execute("SETIND;CUSTOM_CdInsert;OFF")
          Next in line: RRMedia v2.0
          DFX 5.1.1 Skin
          Appstore Link
          My RideRunner Plugins
          RRMedia
          RRExtended
          DFXVoice
            Just tried that, no luck. RR remains as a process for a few seconds after it closed, and thus passes the exists check, but then errors when trying to send something to it.
            This has gotten so frustrating....
            I am using this simple script to test with. If I close RR, I get the error about being unable to communicate with the object.
            Code:
            For $test = 1 to 5
                sleep(1000)
                $RRCheck = IsObj($rr)
                if $RRCheck = 1 then $rr.Execute("SETIND;CUSTOM_WIFI;OFF")
            Next
            How are you setting the variable in the exectbl to 0 when RR exits? A button code would not work well added to the EXIT command, as when you send the power down to the computer, no button code is executed ect, or for some reason RR locks, or does not exit gracefully. I do not want a msgbox holding up the system shutting down.
              Code:
              For $test = 1 to 5
                  sleep(1000)
              Next
              i was using the ONEXIT event that i have in my exectbl.ini.. but as i saying that i realized thats something i added to the latest source myself. Its not official RR code. I can send that beta to ya if ya want though.
                Code:
                	$rr.execute("quit")
                For $test = 1 to 5
                	 if ProcessExists("RoadRunner") = 0 then Exit
                    sleep(1000)
                    if Not IsObj($rr) then exit
                	If @error then ContinueLoop
                Next
                send that to guino also and hopefully can be added for the next release, i can use that feature as well.
                BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
                RRTube ==> [View/Download Youtube Videos]
                WifiMan ==> [Wifi Manager]
                RRec ==> [Audio Capture]
                If You Want To Be Given Everything, Give Everything Up ...
                Bird York -- In The Deep --
                  I second that one for sure, as it is such a simple add to RR, but will help with any scripting outside RR 10 fold.
                    well i was gonna just upload a beta but i forgot i updated to the dec. 6th release and copied over my beta . being that the dec. 6 source isnt available yet i'm gonna pm guino and see if he can add it to the dec 6th release before it goes public. its only one line of code it shouldnt be too hard.
                      I dropped using the SDK all together, and am passing commands via RR"s WinHandle. It's not as clean of a way to code things, but I will never see another error pop-up if RR is not running for any reason.
                      The last thing I wanted is to have the system hang on an error msg for someone, possibly causing a dead battery as the computer didn't go into standby/hibernate ect.
                        great minds must think alike... I was just wondering about this exact same thing as I've been getting kinda sick of the autoit message box errors on my script.
                        I was under the impression ONEXIT already existed but I guess i was wrong.
                        04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
                        Fast car, fast PC. ;)
                        http://www.arcdesigns.net/carpc/
                        My TL CarPC ver2
                        FSR Flash Skin w/ moving weather maps
                          it should be effective in the 12-13 binary
                            so on this command, you use it like....
                            Code:
                            "ONEXIT","CLOSEWINDOW;iGuidance"
                            i didnt see any info on the latest skin commands.txt
                              I put the command there, but when viewing the debug it didn't seem like it got to execute it.. I have to review this.
