Old RRConfig.exe
  • Old RRConfig.exe
    Anyone still have older RRConfig.exe (Not Blue's version) and able to send it to me? I don't see it in the zip available on Guino's site either.
    I love new one but for some reason if I use it on my carpc RR will not return from hibernation correctly. Locks up a lot. As soon as I delete rr.ini and re-do it with old RRConfig everything goes back to normal.
    Anyway if anyone has a copy would you please forward it to: jay [at] f-28.com
    it should be in the older version packages of RR -- available in Blue's museum of RR versions -- click on his sig.
    Ride Runner RR's Myspace
      Thanks. Did not see that in his signature.
        If you do a little research and figure out what is causing the prob, post it in the config thread as I am finishing my media plugin and will be getting out another config update..
        Next in line: RRMedia v2.0
        DFX 5.1.1 Skin
        Appstore Link
        My RideRunner Plugins
        RRMedia
        RRExtended
        DFXVoice
          My apologies to Blue. It ended not being his config.
          Traced the problem to RR hibernate command. Guino, what are you using to set hibernation state? If I hibernate from a skin it will not boot back OK. If I push the power button or run "rundll32 powrprof.dll,SetSuspendState" everything goes OK.
          Any insight?
