New RR Version - GPS Not Working
  • New RR Version - GPS Not Working
    Ever since I upgraded to the 12/6 version of RR, I cannot get GPS to work. Now when I click the GPS button, it does nothing at all. The only way I can get it to do anything is to set gps to external... But when I have it set to MapMonkey.. when I click the GPS button it doesn't do anything at all..
    Anyone else have this issue?
    Just reverted back to the November version.. GPS working fine again.. this IS a bug in the new December version...
    Anyone else have this problem???
      yes I had this problem too. I thought it was a problem with Xport not starting up, but when I'd bring up Xport, it was working fine. But i did notice that RR was supposedly using it's assigned port from Xport even thought it wasn't working in RR. I'm not sure what fixed it, but it's now working after a few days of not working.
      In my case, RR isn't shutting down properly with this new version. RR shuts down and resumes properly when I shut down the computer manually in windows. But if I turn off the car and turn it back on (and let the system shut down on its own), then RR is not resuming from when I last turned off the resumes from the last point where I had manually shutdown windows. since I've never had this problem in the past (and the GPS problem too), it makes me believe that they are related somehow. maybe RR didn't shut down the port properly???
      Hope it helps give you somewhere to start looking...
      Toyota Tacoma Install
      BMW 325Ci Install - Old
      ZOTAC H55-ITX, Intel i3 & 320 Series SSD
      7" Lilliput 669GL, M4-ATX, SB X-Fi, XMPCR
      Win 7, RR, Garmin, DashCmd
      Morel Elate 9 3way & IDQ10 ported (active 4-way),
      JL Audio HD Amps, Audison BitOne.1
