Someone please help - RR not saving song on exit
  • Someone please help - RR not saving song on exit
    I've been having this problem for almost a year. I figured something was wrong with my system but I did a full XP reinstall and reinstalled the latest rr (12/13) along with winamp 5.13. Note that when I first had the carpc it did work properly.
    The problem: RR will more often than not lost the songs in the playlist on exit. For example, I start with a blank playlist, browse to an album and add all the songs. I now have an "on-the-go" playlist. Everything's going well but when I exit road runner (usually by standby but even just exiting normally) and resume, either
    1. the playlist is empty
    2. the playlist is still there but instead of resuming playing music where it was, music is stopped and the song selected is one that was playing a few songs before I exited
    3. it works as it should (very, very rarely)
    Is there anyone that might know what's going on or is there anything I can put in exectbl to force rr to save the current location on exit/standby and force it to reload the saved position on reload? I primarily use standby for 2 hours and then a hard off.
    Anyone out there know what's going on? This is like the last hurdle to overcome having a great, fully functioning system and I promise not to mess with it any further if I get this working... haha.
    TIA!
    Chris
    It may be caused by a com port not closing correctly, stopping RR from saving the resume.ini file (and any other changes). Try unplugging any usb devices that you can, or anything else using a com port and see if things work. If it works, then try isolating which one is causing the problem and check drivers. I was having a similar problem caused by a serial to usb adapter.
      Is there a way to actually diagnose the problem rather than just unplugging a bunch of stuff and hoping that it can be isolated?
        Did you mess with the Hibernate aware Setting in RR.ini? Not sure if this applies, but putting hibernateaware=false in my ini solved a similar problem for me.
          I didn't change it from the default hibernateaware setting. I will try both suggestions a little later today and let you know.
          Would the hibernateaware setting and the suggestion regarding USB devices/com ports affect just exiting roadrunner and not even going into standby? Because it loses the playlist even when just exiting and reloading the skin
            ok, just tested both suggestions and unfortunately neither one fixed the issue. I changed hibernateaware to false and also tried running with nothing USB except the mouse. Still won't save my current playlist on exit.
            I dont know what the values in resume.ini correlate to but for reference here's what it currently is:
            -1
            -1
            false
            false
            path of skin here
            0
            false
            false
            false
            false
            That mean anything to anyone? I have resume music set to always in rr.ini.
              You probably should post your entire rr.ini file.
                A good idea!
                Here's my rr.ini
                [General]
                winamppath=C:\Program Files\Winamp\
                hidewinamp=false
                launchpath=Click here to set path
                startcommand=
                voice=false
                disableinternat=false
                exitmute=false
                showicons=false
                showextensions=false
                hidemouse=false
                hidetaskbar=true
                hidedesktop=false
                hidedots=false
                gpstime=false
                gpsusadate=false
                exitmode=0
                dateformat=MM/DD/YY
                timeformat=HH:MM AM/PM
                locale=0
                screentype=16:9
                debugmode=false
                enableclipping=true
                nozoom=false
                usegestures=false
                leavemousealone=false
                closeapps=false
                fastmode=-1
                usedualmon=false
                soundcard=0
                screenlimit=3
                mastervolmap=0
                forcehibernate=false
                hibernatereload=false
                usbsound=false
                browsertype=1
                browserpath=C:\Program Files\Internet Explorer\iexplore.exe
                usevoicecontrol=false
                usecar2pc=false
                fadeinvolume=true
                [Skins]
                skinpath=C:\Program Files\Road Runner\Skins\LSX VOID 3.0\
                transition=-1
                backgroundpath=To set path,Click --->
                [Gamma]
                gammamode=3
                gpsgammamodeoffset=0
                gammaday=0:0:0
                gammanight=-50:-50:-50
                gammadaytime=1:00
                gammanighttime=1:00
                autogammamode=2
                autoskinmode=1
                [Preload Screens]
                preload=
                [Music]
                musicpath=C:\Music\
                playlistpath=Click here to set path
                useid3=2
                showid3playlist=true
                showid3browse=false
                lazytag=false
                singleclickaudio=false
                noformat=false
                listnumbers=true
                listfollowssong=true
                resumemusic=2
                audiorepeat=last
                audioshuffle=last
                id3listformat=%title%
                id3browseformat=%title%
                titlesafter=-
                albumart=*.txt
                fadeimages=true
                audiofiles=.mp3, .exe
                visuname=!Winamp Gen!AVS
                scrollmode=1
                circularlist=false
                groupnumbers=false
                picspath=To set path,Click --->
                [Radio]
                radiomode=0
                allowallfreqs=false
                radioline=0
                userbds=false
                [XM]
                xmport=0
                xmline=0
                xmlineinplugin=false
                xmtype=0
                singleclickxm=false
                xmformat=%station% %artist%
                [SIRRIUS]
                srport=3
                srline=4
                srlineinplugin=true
                srlineinpar=line://title=SIRIUS,srate=44100,bps=16,nch=2
                singleclicksr=false
                srformat=%artist% - %title%
                [Video]
                videopath=C:\Movies\
                mpcpath=C:\Program Files\Road Runner\
                videoautohide=true
                videohidetime=4
                builtinvideo=true
                videofiles=.mov, .avi, .mp4
                videoshuffle=false
                [TV]
                tvline=9
                [GPS]
                gpsmode=2
                mapmonkeypath=Click here to set path
                gpspath=C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe|nowarning
                gpsname=iGuidance
                overspeed=55
                gpsport=8
                mappointmap=1
                mapcountry=United States
                mapcity=
                mapautozoom=true
                isunits=false
                usegpsserv=false
                gasfinderautorefresh=false
                mapvol=5
                [IG Native]
                ignative=true
                igautosw=true
                gpsonvoice=true
                pauseonvoice=false
                lastscreenswitchtime=5
                [Speed Att Vol]
                speedatt=false
                [Phidget]
                phidget1=0
                phidget2=0
                phidget3=0
                phidget4=0
                phidget5=0
                phidget6=0
                phidget7=0
                phidget8=0
                [4 Temps]
                tcomport=0
                tempscale=c
                temp1=c
                temp2=c
                temp3=c
                temp4=c
                [Volt Meter]
                vcomport=
                [Phone]
                phoconodesign=false
                motophone=false
                phonelistspath=Click here to set path
                contactspicturespath=Click here to set path
                ringtone=Click here to set path
                smstone=Click here to set path
                maxcalllistentries=100
                phoconoincallevent=false
                connecthsp=1
                standardphonebook=0
                phonebooksencoding=windows-1252
                [Weather]
                cityweather=
                weatherunits=USA
                weatherdegress=∫
                localdatacaptureinterval=0
                [Extra's]
                  Try this.
                  Run RR and play whatever you want for a minute or 2.
                  Close RR and let it shut down completely.
                  Restart RR and let see if the music resume where it left off.
                  If it does,there is a problem somewhere with your standby/hibernate setting.
                  Y2K Accord Dell GX150
                  EmoRebellion is a SCAMMER
                    resume.ini line descriptions:
                    -1 (if audio is playing at time of exiting, this is the list position that is currently playing)
                    -1 (current track position)
                    False (repeat T/F)
                    False (Shuffle T/F)
                    path of skin here (current skin path)
                    0 (SpeedAttBaseVolume)
                    False (VideoShuffle)
                    False (?)
                    False (?)
                    False (?)
                    The first line tells me that WA was/is stopped, values are -1=stopped, 4=playing or paused
                    Second line is the song position, and if WA is paused when exiting there is a "-" infront of the position..
                    Don't know why your line 5 doesn't have the currently used skin path??
                    Next in line: RRMedia v2.0
                    DFX 5.1.1 Skin
                    Appstore Link
                    My RideRunner Plugins
                    RRMedia
                    RRExtended
                    DFXVoice
                      thanks for the replies guys. Matrix - I have done that, let rr play and the simply exit. Same problem. I'll try letting it run a little longer though and try again.
                      Bluezx3- that resume.ini was taken right after hitting exit from rr and going right to the file. Music was playing and thats what the ini showed. The ini was located in the rr folder. The skin path shows the proper skin path. I just wrote that line since I'm on my phone and didnt wanna write the whole path out. So since winamp and rr were playing when I exited it seems either rr isn't writing to resume.ini or isn't writing the correct info.
                        I have never had a prob with this prob desc. But that is why your having probs, as rr is stating that on exit that your play status is stopped, even though you say that its playing.
                        DFX 5.1.1 Skin
                        Appstore Link
                        RRMedia
                        RRExtended
                        DFXVoice
                          hmm. I wonder why. Maybe I'll do a debug log and post here to see if that reveals anything.
                            Let me know if you find anything, I've been having the same problem and I can't figure out why.
                              when you exit rr does your resume.ini look simular to the above one?
                              DFX 5.1.1 Skin
                              Appstore Link
                              RRMedia
                              RRExtended
                              DFXVoice
