text color problem
  • text color problem
    I have managed to get RoadRunner working perfectly on 4 machines now. However I just switched to a new machine at home that I use to work on skin ideas among other tasks. Everything functions fine except that I can't get text colors to come out right. When I move the skin to my car, the colors come out as intended.
    I seem to be stuck in the blues (both literally and figuratively). I get blue text when I tried for red in a label on the menu.skin
    It's also happening in a directory list I use in my audio browser. Black text seems to work, and white text seems to work, but if I put in reds, oranges, greens, they all come out the same shade of blue.
    No other program seems affected, including both graphics (Photoshop, Irfanview), text (Word), and browsers like I'm typing this into now.
    It's pretty much a basic install, no tweaking of anything except through RoadRunner Config - and those settings mimic what's working fine in the car.
    Any ideas on what I may have screwed up?
    Weird issue... try making a screenshot of how it looks in a machine that works right, then another of the machine that doesn't work right... before anything, I would check the screenshot files in different machines to see if they look different.. Most labels in RR use standard VB6 functions to choose the color, so it should not be an issue. In any case, check your display settings for color depth -- it may have something to do with that.
    Ride Runner RR's Myspace
      Thanks for looking in Guino.
      Here's a line I added, just to illustrate, from the machine that I'm having trouble with:
      L,302,125,457,51,255,0,0,28,"Arial:B","PLAYLIST"," CENTER"
      and here's a screen cap of the display on the "bad" machine (the text in question is the "In the Studio").
      I tried changing the color depth from 32 to 16 (the only choices I see in the ATI control panel). No help, still a shade of blue (and it's always this same shade). You can see that black text comes out OK as the song length and remaining time, as well as the artist name and song title come out OK. Text labeled as white comes out OK too. But if I pick any color other than black or white, I get this shade of blue.
      In my car (Dell laptop), the text comes out red, as one would expect with a color setting of 255,0,0
        This is puzzling.. seems like VB6 is not being aware of the correct colorspace.
        Would you change "CENTER" to "SCROLL" And see if it works ? (Scroll labels are API-Based -- non-dependent of VB6's handling).
          Let me be the 1 millionth customer - You be the man
          That fixed it...now if you can do one more thing to help a fool like me, what files do I need to load to bring VB6 to full functionality?
            I dont recommend (by any means) making a bunch of scrolling labels on your skin.
            If you're talking about fixing the issue, all I can suggest is that you try to download the latest VB6 runtime files from Micro$oft.
              thanks, that makes sense as one or more may have gotten corrupted overwritten as I installed software on the machine.
                Update: Turns out the problem is with the ATI Catalyst Control Center software (ATI PCI-E video card) that I use to drive an extended desktop across two LCDs. I have no idea why it's stepping on RR like that, but I can live with it since it doesn't do anything to the files themselves, so they look OK in the car.
