F-R fade problem
  • F-R fade problem
    Hi, I have my PC setup with RR running Winamp 2.95 and using a D-link Radio. I am running 6 speaker setup without the centre speaker (so 5)
    All goes through the amps in the car.
    I have a F-R fade imbalance.
    Playing the Radio I can have (on the MB sound mixer) the front and rear up full volume but when playing MP3's through winamp the front is massively biased I have to turn the front speakers down to 25-30% to even it out!
    Is there any settings in Winamp which can control this?
    What are you running for a sound card?
    As a simple solution you could just tweak the amp gains.
      Tweeking the amp gains would not solve the problem, if I set the amp gains to balance the F-R fade playing MP3's it will be out on the radio! If you see my dilemma!
        Oh it's built in sound up to 7.1 capable. tried it on 4 speaker, it's just the same.
          My reading comprehension sucks today.
          I'm sure there's a way to do it with an autoit script where it switches your fade in the radio screen and then back to normal otherwise.
            Try adding something along these lines:
            exectbl.ini
            "Radiofade","SETVOL;FRONT;70||SETVOL;REAR;30"
            "Musicfade","SETVOL;FRONT;30||SETVOL;REAR;70"
            Then add the "Radiofade" cmd to the end of the button cmd that loads the radio...ie
            b,xx,x,x,xxx,xx,x,x,x,"load;radio.skin||Radiofade" ,""
            Then do the same for the exit button on the radio screen...ie
            b,xx,x,x,xxx,xx,x,x,x,"Main||musicfade",""
            Should work, just tweek the values as needed...
            Enjoy!
            Next in line: RRMedia v2.0
            DFX 5.1.1 Skin
            Appstore Link
            My RideRunner Plugins
            RRMedia
            RRExtended
            DFXVoice
              Thanks Blue, I'll give it a whirl.
                I have a problem concerning front-rear balance, so im loaning this thread :P
                I have a 4 speaker setup on my car. I want to chance front-back balance bepending how many people there is in the car. I don't like to use backspeakers if theres nobody sitting there.
                And the problem is i can't adjust balance directly from master volume. I have to adjust balance from Master Volume->Options->Properties->Other->Multi Channel. Attached picture isn't from my car so you cant really see it, but you can see what i mean. So what slidercodes should i use in my mixer skin to change those values in that window? Or is it even possible?
                Hope you understand what i mean
