hd radio help
  • hd radio help
    Need some assistance with my HD radio. Cannot get RR to find it. Any help or tutorials would be great. tried to search, but no can find. Thanks in advance
    you did run my application 1st? right HDRadio PCR
    then there is just two lines you need in the RR.INI file
    radiomode=8
    hdradioport=3
    replace 3, with the comport u got it connected to... if u dont know...
    run HDRADIO PCR without the tuner connected (after u ran it with it connected)
    a dialog will popup, and tell u the comport, it last found the tuner on
    after that... use the right skin...
    thats IT!
    if it dont work, u got something installed and used by roadrunner, that it nabbing the COM port... maybe some lame gps?
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      thanks for the reply mitch. I was trying different com ports, but finally figured it out as 1. Cable works great.
        ok, so you got it all working?
        mitch
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          Thanks Mitch
          This worked for me. I FINALLY have my HD working in DFX 3!
          I knew it was something simple.
          Fred
