will one of my RR bretheren help me out with configuring a visualization?
  • will one of my RR bretheren help me out with configuring a visualization?
    I'm having fits about this cause i know its something simple but i just cant get it. I wish to get winamp to display ONE visualization- then spectrum analyser. I have that loaded and it plays like it should but then 10 seconds later it changes to another random visual. How to i make it so that spectrum analyzer stays put!
    Live mp3Car Facebook Chat
    At least you can get your visuals working, mine always gives me screwy errors
    2003 Nissan Xterra Worklog
    Total amount spent so far: $1196.64
    You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
    2003 Nissan Xterra - Modifications
      Sonic, run winamp by itself then options -- preference...
      ...visualization.... start... then configure
      once u see winamp avs editor, go to settings, presets/hotkeys... there, uncheck, "Randomly switch presets..." close... that's it... which visualization are you using?
        i'm using avs and that worked perfectly. i thought it had somthing to do with the transitions options .. never thought to look in the presets. THANK YOU
          Just a note: You can also make a few colors of the spectrum analyzer by editing the color settings in the configuration and saving them. Then you can MANUALLY change them in Road Runner with the "NEXTAVS" and "PREVAVS" commands to cycle through different colors. I used the label exec code to place those buttons over the album art in my skin. Its a nice touch to be able to change the color to the users preference.
          My Fiero Build Thread
            i noticed that you have the files stored as a part of dfx, i'll have the check those out in greater detail when i get a second
              Yea, in the helper files folder. I made a spectrum analyzer in all the common colors, Red, Green, Blue, Orange, white ect.
              Just pop em in a sub-folder of the AVS/Plugins folder. Then in the same configuration mentioned above, you can tell it to just use visu's from just that sub folder. If you leave it on the root folder, you better feel like pressing the screen a couple hundred times to go through them all
                Son-of-a-gun! That's what i was doing like a big dummy! Not anymore..THANKS.
                OLD SYSTEM (DEAD)
                Intel D945GCLF2 Dual Core ATOM
                Lilliput 7" 629GL 2008 LED Backlight
                BU-353 USB GPS Receiver / iGuidance / IGO8
                M2-ATX Power Supply
                RideRunner Front End / Various Skins
                Windows XP SP3
                  yeah.. i learned all that goodies from the Might John's DFX.. In fact i am learning so much from DFX and help file he compiled.. He also posted in FAQ section or his help file i think on optimizing VIS setting without loosing VIS performance but inhancing the CPU usage significantly... U might wanna check that out guys...
                  Ok, guys,, found the link..
                  http://www.mp3car.com/vbulletin/rr-f...ad-runner.html
                  pay attention to #6....
                    Good info...
                    OLD SYSTEM (DEAD)
                    M2-ATX Power Supply
                    Windows XP SP3
                      Guess i'm going to have to break down and upgrade to 5.13 'cause i don't see those settings in 2.95..
                      OLD SYSTEM (DEAD)
                      M2-ATX Power Supply
                      Windows XP SP3
                        what's holding u back Treetop... That should've been done already dude..
                          I still use 2.95 because it has a smaller footprint
                            Same here but i think we will be forced to upgrade eventually as RR keeps progressing.
                            OLD SYSTEM (DEAD)
                            M2-ATX Power Supply
                            Windows XP SP3
