a noob question.. sorry couldn't come up with more challenging one.. ^^
  • a noob question.. sorry couldn't come up with more challenging one.. ^^
    How do you all hook up ur system to car speakers???
    system: carpc, laptop, umpc, etc....
    I hook up my umpc(hardly, but with little bit of respect ^^)
    to auxiliary input of my dashboard to generate the sound from my speakers... but, i am not sure if i am getting the quality i am looking for.. I am looking for good quality that can be setup rather easily..
    Now, all that complicate wiring and disambleing thing is not my game as i have never done it and have no knowledge of doing it..
    I am not looking to turn my car into some sorta monsterous boombox.. Just wanna get some quality sound.. auxiliary input is a way to do it? how you guys do it those of you using laptop or umpc?
    Thanks for sharing ur knowledge..
    Does not compute.....
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
      Yeah Bran - it don't make sence what you wrote..
      OLD SYSTEM (DEAD)
      Intel D945GCLF2 Dual Core ATOM
      Lilliput 7" 629GL 2008 LED Backlight
      BU-353 USB GPS Receiver / iGuidance / IGO8
      M2-ATX Power Supply
      RideRunner Front End / Various Skins
      Windows XP SP3
        Getting past the lols.
        I'm outputting to a M-Audio Firewire 410 to my amps and on to the speakers. The 410 allows ASIO direct monitoring and all the lovely tuning plug ins for ASIO.
          puhahah... sorry... I was hoping if there's a kit or something for plug and play... something better than what i am using... Didn't realize plug'n play thing is only valid in Mr. Gates world... Well, that's why i am a noob...
          machinehead, plz educate me a little, didn't u have to disapart all the interior to hook up ur amp to the car speakers?
            Yes there is some disassembly but really only the door panels and I took both front seats out at one point to install the amps. Running the wires from the speakers to the amps can be done for the most part without taking anything apart. There are plenty of seams to snake wires through on every vehicle.
              Thanks for sharing ur knowledge.. I'll do some more research on that.. then....
                I haven't built my CarPC yet but I am curently using an inline FM modulator for my XM Radio. It works really well. Since it plugs directly into the antenna jack on the radio, sending its signal directly into the radio, it overpowers any other signal comming in and sounds great! I don't know if I will stick to this solution when I install the PC but it works.
                Kyle
                  well kyle.. i did some googling on that... Sounds like it could be a good solution for guy like me.. Only negative side was that some people had to buy extra adapter to work with their antenna.. Well if you have money and willing to do some wiring then why not go for the better... I got cheap 4.3 inch umpc... but you gonna have CARPC that deserves good hardware.. ^^ I am sure you won't be disappointed..
                  Thank you for ur sharing...
                    Laptop headphone out--3 way crossover--4 channel amp/2 channel sub amp--speakers.
                    Sound quality is just as good or better than a normal head-unit.
                    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
                    MediaLaunch for RR
                    Online Check for RR
                    Locker for RR
