Prob with Silabs USB.. HELP !!
  • Prob with Silabs USB.. HELP !!
    Hi, got a prob with me new Silabs USb stick. it all works great on main machine but when transfer to car pc. I get no sound from RR.
    Version using on both machines is 2007/04/11
    I look through both pc's and i think the stick is installed correctly. On car machine i have used the Silabs test program by Enforcer= Tune and sound from stick.
    However when run RR on car pc and then select radio i get nothing. config is same. Ie from RR.Ini=
    [Radio]
    radiomode=7
    allowallfreqs=true
    radioline=5
    userbds=false
    the skin i am using is the same skin copied across from main machine. Here is the button to launch the radio skin
    B28,646,415,140,111,"RADIO",""
    Has anyone got any suggestions or had simlar probs. have lloked through the posts but to no avail !!
    VIA EPIA M10000 LVDS 1Ghz Motherboard,
    256Ram,80Gig,
    Lilliput 7" In Dash Touchscreen
    Panasonic Slimline Slot-in Cdrw/dvd Player,
    USB Gps Reciever,
    Belkin Bluetooth dongle
    Belkin USB wifi
    Carnetix CNX-P1290 60W Power Regulator
    I'm not sure, but I don't think "radioline" is necessary. Try setting that to 0
      ok will give it go. but have seen in the other posts that silabs need the 7 setting
      This beeing same as one i have in my main pc
      256Ram,80Gig,
      USB Gps Reciever,
      Belkin USB wifi
        Yes, radiomode should be 7, but radioline should be 0. That tells RR which audio line to mute/unmute. Since it's audio is USB, you have no "line" per se
          Ah ha... thx. will give it go now
          256Ram,80Gig,
          USB Gps Reciever,
          Belkin USB wifi
            Hey Hey it works ... nice thanks for the help. Appreciate it.
            Changed the line in to 0 and not 5.
            Just need to wire in my antenna now.
            Thx !!
            256Ram,80Gig,
            USB Gps Reciever,
            Belkin USB wifi
