SENDKEY command
  • SENDKEY command
    Im trying to get media player classic to switch audio streams (Shift s) and to turn on/off Subtitles (Shift s) how do i format this with the SENDKEY command to get them to work?
    I think the below are correct for Road Runner:
    ^ Control
    # Windows Key
    % Alt
    + Shift
    So, to send a SHift S you would need:
    "SENDKEY;+{s}"
    I think you made a typo above however, you said that shift S is the same for switching audio streams as well as turning subtitles on and off
    My Fiero Build Thread
      Thanks ill try that here in a min, Shift a is audio streams and Shift s is subtitles
        No that did not work. im trying to modify the rewind and fast forward buttons on you skin to change the audio and turn subtitles on and off, it is Media player classic thats playing the video in the embedded player correct?
          I had to use "activate" for it to work with mpc.....i'll see if i can dig up that code i used, for a sample.
            this should work
            subs on/off
            "ACTIVATE;- media player classic||SENDKEY;{w}"
            next audio
            "ACTIVATE;- media player classic||SENDKEY;{a}"
            prev audio
            "ACTIVATE;- media player classic||SENDKEY;+{a}"
            your hot keys may differ, hope this helps.
              I read your last post a little closer, this won't work with RR's embedded video player.....you have to manually embed MPC for sendkeys to work. it will take some tweaking for it to embed clean...so the control bar, menu, etc doesn't show
              EDIT: actually I don't remember if I manually embedded it or if putting in MPC's path in rrconfig and un-selecting built in player worked. If you can't figure it out let me know what you are trying to do and I can give it a go for you
                Could not get that to work its with media player classic embedded in dfx3.0 skin if that helps
                  how are you embedding MPC? did you unselect built in player in config or did you change the "video" button code? can you right click on the video(inside of RR) to bring up mpc's menu.....if not then your using road runners video player (which is different than MPC) and sendkeys will not work.
                    just unchecked built in player option and bam it worked!! thanks brew thats the last thing i needed to fix so i can lock down my software part
                      Right on, glad to help.
                        I think i am stupid because i can't use well the send command.
                        I have a button in a skin like that:
                        B08,280,557,59,37,"ACTIVATE;GoogleTraffic||SENDKEY ;{F1}","Right Click"
                        Who GoogleTraffic is a autoit window script with google traffic embedded .
                        In my auto it I have define en function for the F1 key:
                        Code:
                        HotKeySet("{F1}", "_MouseClickRight")
                        if I push on my F1 key the autoit script run this function (right click mouse):
                        Code:
                        Func _MouseClickRight()
                        	MouseClick("right", 500, 300, 1, 10)
                        EndFunc
                        I don't know why if i push on my skin button the SENDKEY;{F1} don't run .
                        Where is my error please .
                          Code:
                          Code:
                          EndFunc
                          Unfortunately SENDKEY doesn't work for everything.. I would suggest making a simple AI script exe with the commands you want to use (like the mouse click), and using the RUNQ command to run them instead of trying to simulate key presses in the process -- it will be more reliable and easier to make them work.
                          Ride Runner RR's Myspace
                            Do you have a little exemple please ? (autoit and button command?)
                            Is it possible to add this possibility feature in a last RR revision ?
                              why dont you try to use COPYDATA/SendMessage, a lot cleaner. i think i have an unfished vb ext plugin that can do mouse clicks, i use part of the code in my youtube plugin, pm me if you want it.
                              BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
                              RRTube ==> [View/Download Youtube Videos]
                              WifiMan ==> [Wifi Manager]
                              RRec ==> [Audio Capture]
                              If You Want To Be Given Everything, Give Everything Up ...
                              Bird York -- In The Deep --
