Checking if .SDK object exists (and how to handle it if it doesnt) in VB6
  • Checking if .SDK object exists (and how to handle it if it doesnt) in VB6
    Hi,
    Ive written an app for RR which uses the RR.SDK (COM/API objects).
    When I resume from hibernation or if I shutdown RR before shutting down my application, the app crashes . Im pretty sure this is because it cannot find the RR.SDK object. Can anyone tell me how to make my app check for the existance of the object - so my program knows when RR is running and I can write some error handling routines. I need a way to also continuously check. Perhaps every 1-2 seconds.. As RR may be shutdown/hibernated at any time.
    That way I can make the app either:
    a) force my app to wait till RR (re)loads/reinitialises (eg: resuming from hibernation) before it continues sending commands to RR.
    b) save the application's current settings and then exit. This would occur when it still hasnt found the RR object after 5 seconds, so obviously RR has been shutdown. (Previously it would just crash... losing all the setting)
    I'm using VB6.
    Ice
    Code:
    Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" ( _
        ByVal lpClassName As String, _
        ByVal lpWindowName As String _
    ) As Long
    X = FindWindow(vbNullString, "RoadRunner")
    If X <> 0 Then RoadRunner = True
      Thanks. I'll try that.
      How can I display the current value of SDK as a text caption?
      My app:
      Code:
      Dim SDK As Object
      Set SDK = CreateObject("RoadRunner.SDK") 'Roadrunner sdk decl.
      EDIT: Using FindWindow would I need to check if RR exists before every single send/receive to it? is there any other way (interrupts) rather than polling?
        Try something like this:
        Replace your SDK.Execute("xxx") and your SDK.GetInfo("xxx") with the below subs
        Example: RR_Execute("AUDIO") OR CurrentTrack = RR_GetInfo("TRACKPATH")
        Code:
        Public Sub RR_Execute(sCMD As String)
        	' This would execute a RR CMD
        	' and on error, would reset the COM Obj
        	' then resend the RR CMD
        	SKD.Execute(sCMD)
        	On Error GoTo ErrorTrap
        ErrorTrap:
        	SDK = Nothing
        	SKD.Execute(sCMD)
        End Sub
        Public Sub RR_GetInfo(sCMD As String)
        	' This would Get Info From RR
        	' then re-attempt to get the wanted Info
        	Dim Value As String
        	Value = SKD.GetInfo(sCMD)
        	RR_GetInfo = Value
        ErrorTrap:
        	SDK = Nothing
        	RR_GetInfo = Value
        End Sub
        Next in line: RRMedia v2.0
        DFX 5.1.1 Skin
        Appstore Link
        My RideRunner Plugins
        RRMedia
        RRExtended
        DFXVoice
          Thanks blue. I tried that code.
          Where is says SKD.Execute(sCMD) should it be SDK.Execute(sCMD) instead? I corrected it myself and it works.
          Trouble is the On Error doesnt seem to work is it because the SDK.execute function is the one thats actually crashing, so the error is internal to it rather than the RR_execute sub?
          I ended up using this
          Code:
              If FindWindow(vbNullString, "RoadRunner") <> 0 Then
                  Set SDK = Nothing
                  SDK.Execute (sCMD)
              Else
                  Wait_for_RR
              End If
          End Sub
          Is you errortrap code more efficient - if so, Id prefer to get that working .
          The reason I reset SDK is because if RR is closed and then reopened with my app still running, it doesnt know to reset the SDK = "rr.sdk" unless I do it in that subroutine. Unless you can think of another way it can detect that? I feel that getting the SDK errotrap to work would be best!
            I'm thinking that what you have there might be best for what you doing, my example above is very close to what I'm currently using in my Media AutoIt script.
            DFX 5.1.1 Skin
            Appstore Link
            RRMedia
            RRExtended
            DFXVoice
              I'm pretty sure your method would (should) work.. and it would be better.. but I just cant seem to get it working :s. I dont know if its me.. or if its the SDK.Execute routine.
              Thanks for your help so far regardless .
              Now I gotta figure out how to make a routine which waits (infinite time) for RR to load, or simply aborts the app if you click OK on the msgbox.
