INTERNET / FM Radio
  • INTERNET / FM Radio
    how can i switch the "normal" Radio on/off ? RADIOMUTE didnīt work on my machine.
    if the Internet Radio is on it shows in the WinAmp window the information of the selected station, is it possible to show these information in RoadRunner too ?
    btw. thanks john for the example in your digitalFX skin, but how can i switch the internet radio on.
    If radiomute didn't work you might want to try the direct line mute built-in to RR. I think it goes something like "MUTE:X" where x is the line number for the particular mixer channel.
    On the internet radio you may want to peruse some of my old posts on the subject. It seems with the latest RR beta you have a 50/50 chance of TRACKNAME working or not. If it doesn't I have an old compile that does work. Some references to get you up to speed:
    http://www.mp3car.com/vbulletin/1042232-post271.html
    http://www.mp3car.com/vbulletin/wire...ml#post1001426
    http://www.mp3car.com/vbulletin/993268-post2.html
    http://www.mp3car.com/vbulletin/road...tml#post968085
    Example old code that works:
    http://www.mp3car.com/vbulletin/1124278-post67.html
    Good luck
      thanks for quick answering.
      i use the RoadRunner version from 02.11.07 because the version from 06.12.07 didnīt work with the albumbrowser from @SAL.
      so i will have a look in all links you are given and hope it will help.
