Can't get this crap to work.
  • Can't get this crap to work.
    I've been fighting with RR since the day after I installed it. I got it working good then made some changes like the spinning logo etc. Everything still worked fine, then out of nowhere it uses 100% of my cpu and I can't do anything.
    I will close it and it opens right back up. After I close it the second time it stays closed and my pc is back to normal.
    How do I fix this?
    And why does it open up after I close it the first time?
    Too vague.
    Open rr.ini. Set debug=true.
    Next time it happens, open debug.txt in the RR folder and post up the contents.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
      Make sure you start with a blank debug file before you turn "debug" (in RR config) on, or it may be too large to sift out the problem.
      Leonardo Da Vinci
        High CPU load is generally a FLASH install issue -- please follow the FAQ to troubleshoot it.
        Ride Runner RR's Myspace
          Also the fact that you changed the spinning logo and all hell broke loose, sort of points to flash as well because those logos are all flash.
          Have you done the regsrv32 command?
          1.9in x 2.9in -- 47mm x 73mm
            What is the regsrv32 commnad?
            I found the vfaq, but the 2 files I have after download is flash9e and flash9f. Which one do I rename?
              Debug was set to true. I tried setting it to false no luck. I cleared out my debug file and opened up RR again to get a fresh look and this was the the debug.txt file
              4/15/2008 3:57:48 PM: Start -- Version: 12/13/2007
              4/15/2008 3:57:48 PM: Master Vol: Volume Control/4
              4/15/2008 3:57:48 PM: GetLineControl Failed: 401
              4/15/2008 3:57:48 PM: No Treble Support
              4/15/2008 3:57:48 PM: No Bass Support
              4/15/2008 3:57:48 PM: Source: Wave=&H1008/1
              4/15/2008 3:57:48 PM: Source: SW Synth=&H1004/2
              4/15/2008 3:57:48 PM: Source: CD Player=&H1005/3
              4/15/2008 3:57:48 PM: Source: PC Speaker=&H100A/4
              4/15/2008 3:57:49 PM: Error loading plugin: Motionlock (ActiveX component can't create object)
              4/15/2008 3:57:49 PM: Sim.WMSGs: 1
              4/15/2008 3:57:49 PM: Enter Exec: False, menu.skin, , False
              4/15/2008 3:57:49 PM: Que Exec: True, menu.skin, "ONSKINSTART", False
              4/15/2008 3:57:49 PM: Executing: RUNQ;C:\Program Files\RoadRunner\skins\skins\DigitalFX 3.0\Scripts\AutoLaunch.exe
              4/15/2008 3:57:49 PM: Shell: "C:\Program Files\RoadRunner\skins\skins\DigitalFX 3.0\Scripts\AutoLaunch.exe"
              4/15/2008 3:57:49 PM: Que Exec: True, menu.skin, "NetCheck||Counter", False
              4/15/2008 3:57:49 PM: Executing: RUNQ;C:\Program Files\RoadRunner\skins\skins\DigitalFX 3.0\Scripts\netcheck.exe|209.85.165.147
              4/15/2008 3:57:49 PM: Shell: "C:\Program Files\RoadRunner\skins\skins\DigitalFX 3.0\Scripts\netcheck.exe" 209.85.165.147
              4/15/2008 3:57:49 PM: Que Exec: True, menu.skin, "Counter", False
              4/15/2008 3:57:49 PM: Executing: RUNQ;C:\Program Files\RoadRunner\skins\skins\DigitalFX 3.0\Weather\Counter.exe
              4/15/2008 3:57:49 PM: Shell: "C:\Program Files\RoadRunner\skins\skins\DigitalFX 3.0\Weather\Counter.exe"
              4/15/2008 3:57:49 PM: SDK command: SETIND;CUSTOM_CDIN;OFF
              4/15/2008 3:57:49 PM: Enter Exec: True, menu.skin, "SETIND;CUSTOM_CDIN;OFF", False
              4/15/2008 3:57:49 PM: Queued: "SETIND;CUSTOM_CDIN;OFF"
              4/15/2008 3:57:49 PM: SDK command: SETIND;CUSTOM_DVDIN;OFF
              4/15/2008 3:57:49 PM: Enter Exec: True, menu.skin, "SETIND;CUSTOM_DVDIN;OFF", False
              4/15/2008 3:57:49 PM: Queued: "SETIND;CUSTOM_DVDIN;OFF"
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetTempBackground||SetApps||SetCommandLabels01||S etAppLabels||SetIcons||PresetLoader||IGSettingLoad er||SetLottoBlank", False
              4/15/2008 3:57:50 PM: Executing: BYVAR;BKGNDSET;BackgroundNotSet<<BackgroundIsSet
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "BackgroundIsSet", False
              4/15/2008 3:57:50 PM: Executing: BackgroundIsSet
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetApps||SetCommandLabels01||SetAppLabels||SetIco ns||PresetLoader||IGSettingLoader||SetLottoBlank", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;AppToRun;MyApp01<<MyApp02<<MyApp03<<MyApp04 <<MyApp05<<MyApp06<<MyApp07<<MyApp08<<MyApp09<<MyA pp10<<MyApp11<<MyApp12<<MyApp13<<MyApp14<<MyApp15< <MyApp16<<MyApp17<<MyApp18<<MyApp19<<MyApp20<<MyAp p21<<MyApp22<<MyApp23<<MyApp24<<MyApp25<<MyApp26<< MyApp27<<MyApp28<<MyApp29<<MyApp30<<MyApp31<<MyApp 32<<MyApp33<<MyApp34<<MyApp35<<MyApp36<<MyApp37<<M yApp38<<MyApp39<<MyApp40<<MyApp41<<MyApp42<<MyApp4 3<<MyApp44<<MyApp45<<MyApp46<<MyApp47<<MyApp48<<My App49<<MyApp50<<MyApp51
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels01||SetAppLabels||SetIcons||Prese tLoader||IGSettingLoader||SetLottoBlank", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp01LB;Music
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels02", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp02LB;Radio
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels03", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp03LB;Video
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels04", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp04LB;DVD
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels05", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp05LB;XM
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels06", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp06LB;Sirius
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels07", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp07LB;Phone
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels08", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp08LB;Utilities
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels09", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp09LB;CD Ripper
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels10", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp10LB;TV
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels11", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp11LB;Weather
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels12", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp12LB;Pictures
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels13", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp13LB;Games
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels14", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp14LB;Gauges
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels15", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp15LB;Browser
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels16", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp16LB;Settings
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels17", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp17LB;Destinator
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels18", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp18LB;Map Point
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels19", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp19LB;Streets & Trips
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels20", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp20LB;iGuidance
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels21", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp21LB;Gas Prices
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels22", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp22LB;Camera
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels23", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp23LB;Traffic Cams
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels24", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp24LB;Calendar
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels25", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp25LB;Media Copy
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels26", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp26LB;Skin Colors
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels27", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp27LB;Lotto
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels28", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp28LB;Net Radio
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels29", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp29LB;Radar
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels30", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp30LB;Scanner
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels31", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp31LB;HD Radio
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels32", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp32LB;External Apps
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels33", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp33LB;Skins
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels34", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp34LB;Sys Diag
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels35", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp35LB;GoogleEarth
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels36", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp36LB;Lyrics
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels37", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp37LB;Jukebox
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels38", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp38LB;TaskMan
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels39", False
              4/15/2008 3:57:50 PM: Executing: SETVAR;MyApp39LB;Gmaps
              4/15/2008 3:57:50 PM: Que Exec: True, menu.skin, "SetCommandLabels40", False
              4/15/2008 3:57:51 PM: Executing: SETVAR;MyApp40LB;Theme
              4/15/2008 3:57:51 PM: Que Exec: True, menu.skin, "SetCommandLabels41", False
              4/15/2008 3:57:51 PM: Executing: SETVAR;MyApp41LB;Wireless
              4/15/2008 3:57:51 PM: Que Exec: True, menu.skin, "SetCommandLabels42", False
              4/15/2008 3:57:51 PM: Executing: SETVAR;MyApp42LB;Movie Showtimes
              4/15/2008 3:57:51 PM: Que Exec: True, menu.skin, "SetCommandLabels43", False
              4/15/2008 3:57:51 PM: Executing: SETVAR;MyApp43LB;RRMedia
              4/15/2008 3:57:51 PM: Que Exec: True, menu.skin, "SetCommandLabels44", False
              4/15/2008 3:57:51 PM: Executing: SETVAR;MyApp44LB;CNN News
              4/15/2008 3:57:51 PM: Que Exec: True, menu.skin, "SetCommandLabels45", False
              4/15/2008 3:57:51 PM: Executing: SETVAR;MyApp45LB;Daytime Map
              4/15/2008 3:57:51 PM: Que Exec: True, menu.skin, "SetCommandLabels46", False
              4/15/2008 3:57:51 PM: Executing: SETVAR;MyApp46LB;Destinator 7
              4/15/2008 3:57:51 PM: Que Exec: True, menu.skin, "SetCommandLabels47", False
              4/15/2008 3:57:51 PM: Executing: SETVAR;MyApp47LB;Clean Screen
              4/15/2008 3:57:51 PM: Que Exec: True, menu.skin, "SetCommandLabels48", False
              4/15/2008 3:57:51 PM: Executing: SETVAR;MyApp48LB;DSMLink
              4/15/2008 3:57:52 PM: Executing: SETVAR;MyApp48LB;DSMLink
              4/15/2008 3:57:52 PM: Que Exec: True, menu.skin, "SetCommandLabels48", False
              4/15/2008 3:57:53 PM: Executing: SETVAR;MyApp48LB;DSMLink
              4/15/2008 3:57:53 PM: Que Exec: True, menu.skin, "SetCommandLabels48", False
              4/15/2008 3:57:54 PM: Que Exec: True, menu.skin, "SetCommandLabels48", False
              4/15/2008 3:57:54 PM: Executing: SETVAR;MyApp48LB;DSMLink
              4/15/2008 3:57:55 PM: Que Exec: True, menu.skin, "SetCommandLabels48", False
              4/15/2008 3:57:55 PM: Executing: SETVAR;MyApp48LB;DSMLink
              4/15/2008 3:57:56 PM: Executing: SETVAR;MyApp48LB;DSMLink
              4/15/2008 3:57:56 PM: Que Exec: True, menu.skin, "SetCommandLabels48", False
              4/15/2008 3:57:57 PM: Que Exec: True, menu.skin, "SetCommandLabels48", False
              4/15/2008 3:57:57 PM: Executing: SETVAR;MyApp48LB;DSMLink
              4/15/2008 3:57:58 PM: Executing: SETVAR;MyApp48LB;DSMLink
              4/15/2008 3:57:58 PM: Que Exec: True, menu.skin, "SetCommandLabels48", False
              4/15/2008 3:57:59 PM: Executing: SETVAR;MyApp48LB;DSMLink
              4/15/2008 3:57:59 PM: Que Exec: True, menu.skin, "SetCommandLabels48", False
              4/15/2008 3:58:02 PM: Que Exec: True, menu.skin, "SetCommandLabels48", False
              4/15/2008 3:58:02 PM: Executing: SETVAR;MyApp48LB;DSMLink
              I turned down the graphics accelerator one notch. Dled the flash8 and tried that, nothing seemed to work.
                Anyway I can just turn the flash off one one of the .ini or .txt files?
                  Well it looks like it is trying to set a label all the time, myabe it is stuck on that. Check exectbl.ini to see what you have against that label.
                  Maybe John can shed some light on this as its the DFX skin.
                    Hmm, I dont' have the exectbli.ini file. What other .ini files could I look into besides rr.ini ?
                      Oh found it. Got it working. Just changed the last label to 49. But now I have 2 dsmlink buttons. How do I delete one?
                        I dont remember it off the top of my head but it something like "regsrv32 [PATH]/flash8.ocx" where the [PATH] is where your flash ocx file is. And I know a while ago there were flash 9 errors with RR.
                        Easiest way to do it, is open IE (yes you need IE unfortuneatly) go to a website like newgrounds and play a flash movie. If it plays, flash should be registered. If it doesnt and the little "Need to install missing something" comes down from above, then just download and install.
                        But it seems your problems are elsewhere, just answering for future reference in case someone finds this thread.
                          I need a refresher, where is the exectbl.ini file? I can't find it anywhere.
                            Try C:\Program Files\Road Runner\Skins\DigitalFX 4.0
                            Assuming your are using v4.0 or replace with 2.0, or 3.0
                              I'm using 3.0. I will upgrade though. Thanks
