Directory list problems
  • Directory list problems
    I can't get the directory list show up on a different screen than audio_browser.skin
    I have those working lines in the file audio_browser.skin:
    Code:
    S01,338,090,287,151,255,100,000,255,100,000,255,100,000,255,100,000,255,100,000,000,000,000,TRUE,14,"8Pin Matrix"
    S02,338,260,287,151,255,100,000,255,000,000,000,000,000,255,100,000,000,000,000,TRUE,14,"8Pin Matrix"
    When I add those to another skin file (audio_browser_adv.skin) the playlist shows up, but not the directory list. What am I doing wrong ?
    Did you add an SD line to the "other" skin or use a SETPATH command after the "other" skin is loaded?
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
      Wow, that worked. I wonder why the SD-line isn't required for audio_browser.skin, but oder skins ?! Anyway, thanks alot .
        The audio_browser, audio_player, picviewer, launch, skin_browser, etc. (RR default) skins have their own set of built in properties.
        All non-standard skins, you need to "give" it the appropriate properties.
