spaces in filepath
  • spaces in filepath
    I am trying to put a photo edit button in my picviewer.skin
    What I want to be able to do is browse my photos in the picviewer skin, select a photo in the directory and open it in an external app to edit, ie open a photo in MSpaint and rotate and save it.
    The button code I am using is
    Code:
    B,60,332,155,52,"SETVARBYIND;CURRENTPIC;PICTURE||RUN;C:\WINDOWS\SYSTEM32\mspaint.exe|$CURRENTPIC$;PAINT;PAINT",
    now this does exactly what I want it to do bar one thing. If the filepath has a space in it, MSpaint cannot open it and gives me an error.
    So the question is...... Is there an easy work around for this space in the filepath problem?
    Thanks,
    Anthony
    Celica GT4 Pilot.
    My Skin Bluetab
    When passing variables, you have to wrap them in quotes if there is a space in the variable.
    Setting a variable with the quote in it, and then wrapping the other variable with it will work like this:
    Code:
    B,60,332,155,52,"SETVAR;QUOTES;"||SETVARBYIND;CURRENTPIC;PICTURE||RUN;C:\WINDOWS\SYSTEM32\mspaint.exe|$QUOTES$$CURRENTPIC$$QUOTES$;PAINT;PAINT",
    If you use the quotes a lot, you can make the exectbl code a little cleaner by setting the quote variable in the ini.
    put this in your Skin.ini: (Or in the rr.ini if you want it to work for all skins)
    QUOTES="
    Code:
    B,60,332,155,52,"SETVARBYIND;CURRENTPIC;PICTURE||RUN;C:\WINDOWS\SYSTEM32\mspaint.exe|$QUOTES$$CURRENTPIC$$QUOTES$;PAINT;PAINT",
    My Fiero Build Thread
      John, your an absolute champ.
      straight forward (and understandable) explanations and codes that work, I couldn't ask for a better reply.
      thanks muchly.
      Celica GT4 Pilot.
      My Skin Bluetab
