Cant Figure out the Label Shuffle/Repeat Indicator
  • Cant Figure out the Label Shuffle/Repeat Indicator
    Hi Guys,
    Tried to make a label indicator for the shuffle/repeat button
    When I click on the shuffle repeat button the indicator does squat, what am I doing wrong?
    Code:
    "BYIND;SHUFFLE/REPEAT;=SHUFFLE/REPEAT OFF<<=SHUFFLE<<=REPEAT"
    2008 350z GT Installed since April 22nd 2011 - Worklog
    2000 Protege Installed Since April 2, 2005 - Intel D201GLY|Fusion Brain|ODBPros ODBII|Engenius|GPS Rikaline|Powermate|Motorized Lilli
    Sound Stage
    Eclipse|MTX|Infinity
    The code for the button: "SHUFFLE/REPEAT"
    code for shuffle indicator: "SHUFFLE"
    Do you have the indicator picture on your down picture ?
    otherwise open the bmv skin in one editor and your own in another and coppy the code.
    Cold weather mobo list: Copy the list and add your board
    my hidden screen in action (youtube) , the worklog , RR Volvoskin
      Trying to use the text/label method as opposed to adding a picture with an on/off indicator.
      Sound Stage
        Use an indicator ("I") definition with the command "shufflerepeat" - it will show the words.
        OLD SYSTEM (DEAD)
        M2-ATX Power Supply
        Windows XP SP3
          ugh cant seem to get that going. "Shuffle/Repeat" using I (Indicator). I do use the Label Indicator for mute, works like a charm, did some reading on the boards some people have done it using L (Label).
          Sound Stage
            for label to show like mute or shuffle/repeat try this
            L,569,487,101,44,255,0,0,23,"Arial:B","BYIND;MUTE; = <<=Mute","CENTER"
            I,568,480,103,49,"MASTERMUTE"
            you can have IND line anywhere you need it and same for the label.
            just change the word Mute in the Label line for what ever word you want to use.
            Riderunner / Genesis
            Plugin Breaker in test BassRR Plugin Player, Wifiman_NET
            New Home for Genesis & BassRR :adding to site ,, Hellfyre night
            Bassrr Beta Release :Version 1.3.7
            Movie_info Release :Version 3.1.0
            Wifiman_NET:Version 1.0.0
            Every Future, Needs A Beginning
              My first post above, I tried this.. I bet is some ; or " out of place or something...
              Sound Stage
                correct
                  What it does with this code is on the skin it shows Shuffle/Repeat and does not change to "Shuffle" or "Repeat" hitting the buttons. It just stays Shuffle/Repeat.
                  If that makes any sense LOL.
                  Sound Stage
                    BYIND;SHUFFLE/REPEAT;=<<=SHUFFLE<<=REPEAT"
                    you have to use SHUFFLE/REPEAT as your IND line this will toggle between the too
                      tyvm for sticking with me on this carputer, will give it a go after work. Thanks again!
                      Sound Stage
                        I don't know for sure but "OFF" is probably missing in that string..
                        OLD SYSTEM (DEAD)
                        M2-ATX Power Supply
                        Windows XP SP3
                          Weird
                          BYIND;SHUFFLE/REPEAT;=<<=SHUFFLE<<=REPEAT" Did not work either.
                          I have tried several combinations. Just not the right one yet
                          Sound Stage
                            This will work..
                            If this is what you're after..
                            It cycles through repeat, shuffle, shuffle and repeat, and off.
                            OLD SYSTEM (DEAD)
                            M2-ATX Power Supply
                            Windows XP SP3
                              YYYYYYAAAAAYYYYY!!! Ty Tree! it worked!
                              Sound Stage
