Europe Weather
  • Europe Weather
    I can't seem to get the weather part to work right in RR. I enter my city/country just how its listed on weather.com and nothing.
    Any way to fix it?
    RR's weather component doesn't work anymore,this just happened today so we'll just have to wait and see if guino can fix it.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
      Simple remove in Function SearchWeather the & "&prod=xoap&par=1009410524&key=c8350c85242b427 8"
      OLD:
      Respond = GetString("http://xoap.weather.com/weather/local/" & StrID & "?cc=*" & StrDaysf & "&unit=" & unit & "&prod=xoap&par=1009410524&key=c8350c85242b427 8")
      FIXED:
      Respond = GetString("http://xoap.weather.com/weather/local/" & StrID & "?cc=*" & StrDaysf & "&unit=" & unit)
      The weather.com doesn't need the key code anymore .
      :: MSCAR ::
      .:: Multimedia System Car ::.
        I WAS WRONG !!! LOL.
        Were the new correct license parameter :
        "&link=xoap&prod=xoap&par=1009410524&key=c8350c852 42b4278"
        OLD:
        FIXED:
        Respond = GetString("http://xoap.weather.com/weather/local/" & StrID & "?cc=*" & StrDaysf & "&unit=" & unit & "link=xoap&prod=xoap&par=1009410524&key=c8350c8524 2b4278")
        The fixed Function :
        Code:
        Public Function SearchWeather(ByVal StrID As String, Optional DaysF As Boolean = True, Optional unit As String = "m", Optional Map As Boolean = True) As String
        Dim Respond As String
        Dim StrDaysf As String
        Dim StrMap As String
        Dim WFIle As String
        Dim tfile As Integer
        Dim WeatherLicense As String
        SearchWeather = ""
        WeatherStrUnit = unit
        WFIle = MyPath & "myweather.xml"
        If DaysF = True Then StrDaysf = "&dayf=5"
        WeatherLicense = "&link=xoap&prod=xoap&par=1009410524&key=c8350c85242b4278"
        Respond = GetString("http://xoap.weather.com/weather/local/" & StrID & "?cc=*" & StrDaysf & "&unit=" & unit & WeatherLicense)
        If Respond <> "" Then
            If FileExists(WFIle) = True Then Kill WFIle
            tfile = FreeFile
            Open WFIle For Output As #tfile
                Print #tfile, Respond
            Close #tfile
            DoEvents
            If FileExists(WFIle) = True Then Call GetWeatherInfo(WFIle)
            SearchWeather = Respond
        Else
        End If
        End Function
        :: MSCAR ::
